4.7 fd into 5th gear b16tranny at 1/4
Old Dec 23, 2003 | 07:23 AM
jeremy.'s Avatar
Default 4.7 fd into 5th gear b16tranny at 1/4
still debating on a final drive for the future....i've seen 4.7's pull better et's the 4.9's. but i plan on putting in a ls 5th gear and was wondering if i used a 4.7 final drive in a b16...would i have to shift into 5th at a 1/4 track?
Old Dec 23, 2003 | 08:40 AM
TREVER's Avatar
Default Re: 4.7 fd into 5th gear b16tranny at 1/4 (ek_jeremy)
depends on your tire size and trap speed you can figure it out here
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
most likely not though
Old Dec 23, 2003 | 09:21 AM
MaxBoost's Avatar
New User
Default Re: 4.7 fd into 5th gear b16tranny at 1/4 (TREVER)
you probably won't but it all depends on horsepower, tire size, maximum rpm, etc....
I'm planning on using a 4.76FD, crossing the traps at 8500rpm on 24.5" slicks at around 117mph!
If not perhaps 23*8*13 slicks with the 4.76, 9000-9500
Old Dec 23, 2003 | 02:10 PM
RayB's Avatar
I'd be surprised if you make it to fifth in the quarter. I've never made it to fourth myself.
Old Dec 23, 2003 | 05:16 PM
Austin's Avatar
USDM itr tranny, JDM Final Drive, BFG 205-50/15's and I'm around 8,300rpm in 4th gear at the line while pulling a ~13.7-13.8.
Here's a great calculator that helps you out with gearing:
Austin
Old Dec 23, 2003 | 09:24 PM
Dancing is Forbidden's Avatar
Default Re: (RayB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RayB &raquo;</TD></TR><TR><TD CLASS="quote">I'd be surprised if you make it to fifth in the quarter. I've never made it to fourth myself.</TD></TR></TABLE>SHOOOOT. I make it into 4th in the eighth in my ls.
Old Dec 23, 2003 | 09:25 PM
Default Re: (Austin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">USDM itr tranny, JDM Final Drive, BFG 205-50/15's and I'm around 8,300rpm in 4th gear at the line while pulling a ~13.7-13.8.
Austin</TD></TR></TABLE>what engine?
Old Dec 24, 2003 | 09:17 AM
Austin's Avatar
Default Re: (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote">what engine?</TD></TR></TABLE>
B18C5, 2001 Type-R.
Austin
Old Dec 24, 2003 | 09:57 AM
B18C5, 2001 Type-R.
Austin</TD></TR></TABLE>ok I was like DAMN!!!!!!!
Old Dec 24, 2003 | 11:17 AM
chad's Avatar
Moderator
i hit 5th in the quarter mile with my b20tec with 4.785 in b16 tranny with 180 hp
Old Dec 24, 2003 | 03:58 PM
smokey2.0's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">i hit 5th in the quarter mile with my b20tec with 4.785 in b16 tranny with 180 hp</TD></TR></TABLE>
what's your best et? what size tires/rim? what's the car weight?
i'm thinking of doing the 4.78 thing, but i might need more rpms out of my crvtec
79malibu
Sep 20, 2015 08:25 PM
hamadiscool
Dec 20, 2010 04:46 AM
MoiMotorsports
Aug 3, 2010 04:46 PM
Si-ONARA
Nov 19, 2008 07:20 PM
twilightprotege
Jul 14, 2006 08:53 PM
