trouble, please help if u can
Old Dec 23, 2003 | 06:05 AM
ImportStreetSeen's Avatar
Default trouble, please help if u can
Ok here it is with this damn car , I start my car and it Idling between 0 and 1RPM it feels like its going to stall out. Its a 90 Accord EX. When i hit the gas in the car,, it takes a couple of seconds for the car to register that im hitting hte gas, im thinking it can be something with the fuel pumps or maybe even water in the gas. Please respond to this.
I woukd appreciate your guys help
Thanks
Old Dec 23, 2003 | 06:22 AM
TomSlick's Avatar
Default Re: trouble, please help if u can (ImportStreetSeen)
Well, with that description, it could be a lot of things. First, I assume you meant running between 0 and 1K RPM...
Since it's running at all, you can eliminate some things. From what you've said, it sounds like it could be related to the EFI system, but that's not definite.
When you hit the gas, does the engine spin up and run pretty smoothly (after those couple of seconds)? Or does it choke and die? Or does it spin up, but sputter and gag?
When is the last time you tuned it up? (plugs, filters, PCV valve, etc.)
Old Dec 23, 2003 | 06:28 AM
Default Re: trouble, please help if u can (TomSlick)
AFter i hit the gas, it spins up and feels like its goin got stall, but it does not stall out.
I tuned it up in the beginning of the year around Feb and March, i just started happening today
Old Dec 23, 2003 | 06:44 AM
TomSlick's Avatar
Since it spins up and doesn't stall, I'd say it's not your fuel pump or filter (it would stall out or run really bad if they were weak/clogged).
Check your plugs, distributor, rotor, and wires.
Old Dec 23, 2003 | 06:49 AM
Ya@inlinePRO's Avatar
sounds like the ignition system is going bad.
Old Dec 23, 2003 | 06:53 AM
Default Re: trouble, please help if u can (kwik2nec)
Just had an ignition system put in it over the spring
Old Dec 23, 2003 | 10:40 AM
brads94accord's Avatar
by any chance is the AC on?
Old Dec 23, 2003 | 12:18 PM
Default Re: (brads94accord)
nah, dont use it in the winter lol. i asked my friend he sai dit coul be the distributor cap and the sparkplugs and wires, thanx for your help guys. After i get this car fix im Selling it for 4000, everythign but the system. Gettin my 01 3.2TL,
Old Dec 23, 2003 | 07:20 PM
Default Re: (ImportStreetSeen)
it is probably something to do with your ignition system. mine did that but it ended up being my ac system. but you don't use your ac so it couldn't be that.
Old Dec 24, 2003 | 12:13 AM
5gccord's Avatar
It sounds like your fuel filter need to be changed
Old Dec 24, 2003 | 07:04 AM
Default Re: (5gccord)
did that already, i did it a couple of month ago, i think its my distributor
Old Dec 24, 2003 | 02:42 PM
.bagged's Avatar
check your ignitor...
Flwr
Honda Civic (2006 - 2015)
21
Dec 18, 2007 03:25 PM
eg6turb0
12
Jan 15, 2005 08:02 PM
eg6turb0
Jan 10, 2005 11:44 AM
Bajerek
Feb 5, 2004 11:38 AM
TheRealBenzo
Mar 16, 2003 09:39 AM
