Cold Air Intake
Old Dec 23, 2003 | 03:38 AM
yasir4u's Avatar
Default Cold Air Intake
Hi I have a cold air intake installed ... i know it would consume more gas cause of more air .. can anyone tell me is it worth keeping it or is it not? and the oher thing is that the cold air intake;s filter is down near the ground do you recommend it near the ground or inside the hood .. thanks !!
Old Dec 23, 2003 | 07:37 AM
skabone's Avatar
Default Re: Cold Air Intake (yasir4u)
you won't use that much more gas if you don't slam on the pedal all the time. I got better gas milage after I put it on, but I don't gun it all the time. if you want the filter in the engine bay you should have gotten a RAM intake. the only thing you might have to worry about with the CAI is hydro lock, but that's only if you drive through a huge puddle and submerge the filter. drive with some common sense and you'll be fine.
Old Dec 23, 2003 | 08:13 AM
knowtomorrow3001's Avatar
Yeah the ram air would give you less cold air coming in so you would get less Hp. When you have a ram air it gets a lot of heat of the engine. But just forget about the bolt-ons and get a turbo or engine swap. I wish I had. The intake really doesnt change the gas mileage. If you put H and E with it that probably would.
Old Dec 23, 2003 | 12:22 PM
fw190bvi's Avatar
Default Re: Cold Air Intake (knowtomorrow3001)
thats not neccersarily true......no matter what ur setup is, the better the engine can breathe the better of it is...+ sum ppl (like me) have no plans of putting in 5K to get 50 more whp......if ur cai is AEM, which are the best, then if u worried about hydrolocking, get the bypass vavle.......
Old Dec 25, 2003 | 10:37 AM
yasir4u's Avatar
Default Re: Cold Air Intake (skabone)
hey you know what i smoked Mazda r-6 with my accord 98 v6 with the intake and ya i dont think there is a lot of affect on the milage thanks for all of you guyz
Old Dec 25, 2003 | 02:08 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yasir4u &raquo;</TD></TR><TR><TD CLASS="quote">hey you know what i smoked Mazda r-6 with my accord 98 v6 with the intake and ya i dont think there is a lot of affect on the milage thanks for all of you guyz </TD></TR></TABLE>
your butt is playing trick on you, that's why there's dyno machine
when you replacing the shiny intake you are...
bypassing the resonator(less restriction), bigger tube size(most of the car, yes) for more air flow, and perhaps a better flow filter
most of the time, remove all the restriction give you a slighty better mileage
Greyhead
Honda CR-V & Element
Mar 18, 2014 05:35 PM
bopbop93030
Mar 13, 2008 05:48 PM
SiMateoAko
28
Jul 1, 2005 12:14 AM
xcathodex
Mar 23, 2003 07:54 PM
Blockhead G
Jun 6, 2002 10:10 PM
