H22 SWAP 95 ACCORD EX...Did Search: Results 0
Trying to put a 98 h22 motor in a 95 ex. Which harness do I use? accord harness right? Which dist.? h22 guts inside accord dist. right? now which injectors and what injector plugs-harness? I'm going to use a 95 h22 ecu..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN »</TD></TR><TR><TD CLASS="quote">Trying to put a 98 h22 motor in a 95 ex. Which harness do I use? accord harness right? Which dist.? h22 guts inside accord dist. right? now which injectors and what injector plugs-harness? I'm going to use a 95 h22 ecu..
you use the f22 harness but you have to cut and splice several of the h22 sensors on to it. i am sure you need obd1 injectors.. you got to make it kinda obd1 now
