how many distributors have you killed?
Old Dec 22, 2003 | 09:04 PM
thad
Guest
Posts: n/a
Default how many distributors have you killed?
You know it and I know it, Honda distributors suck. my car sat for a few months because of a bad distributor, my friend just killed his third. we are trying to get just one of the four distributors we have to work by swapping sensors ICMs and coils. i feel like taking them out in the back and knocking them into the sky with a baseball bat. of all the people i know that tweak hondas one out of three has had at least one distributor crap out.
thank god for kragen lifetime warranties, they don't ask questions
Old Dec 22, 2003 | 09:13 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: how many distributors have you killed? (thad)
ive rebuilt the one i have now 4 times and my previous one twice!
Old Dec 22, 2003 | 09:58 PM
Rhetoric's Avatar
I havent had a faulty one yet (knocking on wood) but what makes them so bad as you guys described?
Old Dec 22, 2003 | 11:27 PM
MadtownSi's Avatar
I have not had one totally crap out on me yet. But my stock Si one has all this red dust on the inside of the cap and it sounds like the bearing is gone on it. So now I have a total of 3 distributors. When I use one of them my tack only works until 5k then it just drops back to 0 rpms. Anyone have an idea what that problem is??
Old Dec 23, 2003 | 01:10 AM
b19coupe's Avatar
Never had one fail on me, but I have replaced plenty for customers. I even had one on a second generation Integra that was so bad that it caused the timing belt to jump. You could not turn the distributor shaft by hand at all
Old Dec 23, 2003 | 03:21 AM
Tony the Tiger's Avatar
Over a 3 year span with about 50000km on the odometer, I would say I am on my 3rd distributor... Mostly the ICM is the first to go before anything else with running with the MSD 6AL ans HVC coil. I am probably on my 6th ICM, but I managed to find an aftermarket ICM that can take the heat and stress. My current aftermarket one lasted me 3x longer than any OEM Honda ones and 1/3 of the price.
Moroso now sells a line up of high performance Honda distributors... you may want to look into those as alternatives. King Distributors also sell better distributors with better housings and internals to take the added RPM and heat of most modified Hondas nowadays.
Old Dec 23, 2003 | 05:30 AM
jweller's Avatar
Default Re: (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Mostly the ICM is the first to go before anything else with running with the MSD 6AL ans HVC coil. I am probably on my 6th ICM, but I managed to find an aftermarket ICM that can take the heat and stress. My current aftermarket one lasted me 3x longer than any OEM Honda ones and 1/3 of the price.</TD></TR></TABLE>
you wanna share that with us who makes it? I saw nology makes an ICM thats supposed to be better than stock, but I can't find anyone using it or even selling it.
Old Dec 23, 2003 | 08:31 AM
kaosbob's Avatar
Back in '98, that's the reason I did the first swap on my EF. Distributor crapped out on me, and for some stupid reason while the car was sitting, let one of my buddies talk me into doing the D16Z6 swap. Ever since then, I have rebuilt/replaced about 4 of them. I finally sold the Z6 and am building a B16A for the car. But yes, I agree, F**k Honda distributors.
Old Dec 23, 2003 | 09:04 AM
crx12's Avatar
Default Re: (kaosbob)
SIR1 B16 never had a problem except for the rotor screw backing out a few times. Not a big deal though. Rev to 8K all the time.
Old Dec 23, 2003 | 10:48 AM
Gabe_'s Avatar
Default Re: (crx12)
1 from a b17a.
Old Dec 23, 2003 | 11:15 AM
JCushing's Avatar
1 d series here bit the dust. it started to make an awfull screeching noise then my car would die intermittently
Old Dec 23, 2003 | 11:45 AM
hondahans's Avatar
Default Re: (crx12)
Wait until yours goes out (hopefully it won't) we first gens dont have the luxury of warranties due to never being sold here. If it ever does go haywire, just find any 90-91 Integra dist. and swap over everything from the 2. It's all the same entirlely except the housing itself. (some models look a little different on the sensors....same though.) I did this 5 times between 4 dist.'s the only bitch was finding a security type torx bit to remove some of the screws, again later gens win (no torx...). I should have just bought a distributor king warranted one...
Old Dec 23, 2003 | 01:10 PM
98ITR#0020's Avatar
Default Re: (hondahans)
I fried 2 ignitors w/ MSD 6 and one distributor . I since have removed it and no problems since{knockon }
Old Dec 30, 2003 | 09:38 PM
rodimus's Avatar
Default Re: (98ITR#0020)
at first you said hondas dizzy's suck, then you put thank god for kragen's lifetime warranty...
does kragen sell honda oem dizzy's or are you using oem replacement parts from kragen are not the same quality as honda oem?
i've had 60k on my 2000 gsr with no problems so far (knocks on wood)
Old Dec 30, 2003 | 10:56 PM
TodaSi's Avatar
Default Re: (EVOL)
I haven't had any problems with any dizzy, wait, I take that back, my '91 Integ igniter went bad back in '95.
Old Dec 30, 2003 | 11:19 PM
Rhetoric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITR#0020 &raquo;</TD></TR><TR><TD CLASS="quote">I fried 2 ignitors w/ MSD 6 and one distributor . I since have removed it and no problems since{knockon }
. </TD></TR></TABLE>
Why does this happen? I run an msd sci and Im thinking of taking it out now.
Old Dec 31, 2003 | 01:23 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (Rhetoric)
Anybody have any distributors that are gutted they want to sell? I like having stuff like that. But must be for gsr tho.
art
Old Dec 31, 2003 | 06:33 AM
ATYPR's Avatar
Default Re: (Arturbo)
I'm switching over to obd1 and I have a perfect obdo dohc vtec dizzy for sale........
Old Dec 31, 2003 | 07:40 AM
WAFFLES's Avatar
Default Re: (FUCATYPR)
I had a wire come loose in my 95 GSR distributor, and only once might I add. I bought the distributor used, and have yet to have it crap out. I've just done the normal maintenance on it. Once anything gets a good amount of mileage on it, it will need to be fixed/replaced.
Old Dec 31, 2003 | 10:52 AM
BERT-O's Avatar
Anything aftermarket rebuilds from Autozone, Discount, Pepboys, etc is ALL JUNK.........PERIOD.
I love it when a guy comes to my counter, bitch about the price of something, goes to Pepboys, realize it lasted 6 months, goes back, gets another one at Pepboys underwarranty, install its and fails on the same day while happen' to rush home to take a **** but now he stuck on the side off the road while hold on to dear life so he won't **** his pants.
Yeah, not going on OEM is the right thing to do, lol.
*burp*
Old Dec 31, 2003 | 11:21 AM
johnzm's Avatar
Default Re: how many distributors have you killed? (BERT-O)
OEM costs big bux for stupid little parts....
i have an OBD0 car, so finding them for my motor is alot more difficult.
mine failed after about 2000 miles of revving to 10,000rpm
the bearing went bad the rest of the distributor is fine.
also had a 94 del sol VTEC ate 2 coils and 2 ignitors
a mechanic told me that if i had stuffed grease around the bearing it would have lasted..
Old Jan 2, 2004 | 08:23 PM
Qfactor's Avatar
Default Re: how many distributors have you killed? (johnzm)
does any one have obd1 dohc vtec distributor casings for sale, no internals preferably. IM or email me.
Old Jan 3, 2004 | 01:52 AM
10secondhatch
Guest
Posts: n/a
Default Re: how many distributors have you killed? (Qfactor)
When my car was OBD 0 i killed 3(smaller bearings dont like rpm)
Since i changed to OBD 1(3yearsago) i never had any problems
Personally i run 100% honda ignition, no amp, ex coil,
Most people that cant keep a disributor in there car are useing an after market ingition. But thats just what ive seen.
Old Jan 3, 2004 | 07:40 AM
1 2 NV's Avatar
i havent fried any. 8k launches and 9k shifts for 2 yrs now and it came from a daily driver. i got a spare or 2 if i need it though.
Old Jan 3, 2004 | 01:49 PM
B18C2_sedan's Avatar
one from a 1.5 d but it just did not die. It cought fire and melting my spark plug wires to the head. I was just a little bit scared.
