Who can tell me about two-stage nitrous???
Old Dec 22, 2003 | 07:22 PM
Blue97GST's Avatar
Default Who can tell me about two-stage nitrous???
I would like to install a nitrous system on a 3rd gen Lude Si. I like the safety features of the Zex. But I will need a window switch to control the N2O activation points, some kind of ignition timing controller, and I need to limit the amount of N2O in first. I want to run no more than 25 shot for first gear, and then halfway through 2nd I would activate the 65-75 shot.
The problem is I don't know jack about two stage systems and if all that will even work with a zex system. I do know Zex only gives you a 55, 65, and 75 jets, so right there is a problem of finding a 20-25 jet. It's a traction issue. So some one who knows about this could you please enlighten? Thanks
Old Dec 22, 2003 | 09:14 PM
rOby's Avatar
Default Re: Who can tell me about two-stage nitrous??? (Blue97GST)
hit me up on aim= robycold ill give u some info.
Old Dec 23, 2003 | 06:02 AM
MaxBoost's Avatar
New User
Default Re: Who can tell me about two-stage nitrous??? (rOby)
A two stage nitrous setup is pretty much just two nitrous kits installed...
I reccommend you don't use a dry kit. Even for the first stage 25shot..
All you have to do is run a 25shot wet, and then have a direct port/Nozzle/nxl/plate/or whatever 75shot as the second stage. You can also look into a NOS progressive nitrous controller or Nitrous Express' equivalent system. Also for your ignition timing, hondata offers a nitrous control system which gives you a second map that you can switch to when your on nitrous..also remember a fuel pressure cutoff switch, colder plugs, stainless steel exhaust valves, and an msd window switch will all help you keep your motor intact! Good luck.
Old Dec 23, 2003 | 08:05 AM
eddiecut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rOby &raquo;</TD></TR><TR><TD CLASS="quote">hit me up on aim= robycold ill give u some info. </TD></TR></TABLE>
hit up roby he knows more then 95% of the ppl on this board
sean-sports
Sep 9, 2009 08:39 PM
hotimportcrx
Sep 19, 2005 04:52 PM
hotimportcrx
-=TWITCH=-
May 3, 2002 09:22 AM
ridnmyhonda
Jan 9, 2002 06:38 AM
