Vacum leak anyone can help B16
Old Dec 22, 2003 | 07:17 PM
jdmb16si's Avatar
Default Vacum leak anyone can help B16
I have a civic si with a b16 i have a slight leak it idles form about 1200 to 1900.
Old Dec 22, 2003 | 07:58 PM
gumbybum's Avatar
Default Re: Vacum leak anyone can help B16 (jdmb16si)
i need a little more info to help you out. ar you sure its not just your idle that is off? or are you positive that it is a leak? just inspect all of the vacuum hoses, lines and connectors for damage or disconnection. also are you throwing any codes?
Old Dec 22, 2003 | 11:14 PM
mastarolla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb16si &raquo;</TD></TR><TR><TD CLASS="quote">I have a civic si with a b16 i have a slight leak it idles form about 1200 to 1900.</TD></TR></TABLE>
go to checker/kragen/shucks or wherever and buy a mechanics stethoscope and use it to listen around the intake gaskets and vacuum hoses...ull be able to hear the leak very well!!
Old Dec 23, 2003 | 04:48 AM
dustinsterk's Avatar
Default Re: Vacum leak anyone can help B16 (mastarolla)
Just spray carb cleaner on the hoses, and if the idle bogs....you got yourself a leak.
Old Dec 23, 2003 | 11:58 AM
sweet's Avatar
Default Re: Vacum leak anyone can help B16 (dustinsterk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustinsterk &raquo;</TD></TR><TR><TD CLASS="quote">Just spray carb cleaner on the hoses, and if the idle bogs....you got yourself a leak. </TD></TR></TABLE>
Old Dec 24, 2003 | 10:41 AM
Cynical 1's Avatar
Hey! Good for you!
itzyaboyzeem03
Jun 29, 2008 12:00 AM
hondapwr
12
Jan 22, 2006 06:49 PM
88 rex
Sep 25, 2005 04:01 PM
fullraceacura
Jul 26, 2005 10:39 AM
wpgcivic
18
May 16, 2004 08:59 PM
