str tb ....sticky and stiff throttle???
Old Dec 22, 2003 | 06:56 PM
GOLDBERG's Avatar
Default str tb ....sticky and stiff throttle???
anyone else have this problem..is this normal??the throttle is hard as fawk, compared too stock..and the spring seems a lil sticky
Old Dec 22, 2003 | 09:23 PM
jdkindle's Avatar
Default Re: str tb ....sticky and stiff throttle??? (GOLDBERG)
I cannot speak from experience, so dont take this for gospel, but I can see a couple of reasons that may make it seem like that
1. yours could have been worn
2. STR's part are race-bred, so its likely gonna be fairly extreme
Old Dec 22, 2003 | 10:28 PM
Drag_Racer_DRU's Avatar
Default Re: str tb ....sticky and stiff throttle??? (jdkindle)
mine works great... try adjusting your throttle cable, thats what i did and its perfect
Old Dec 23, 2003 | 12:24 AM
GOLDBERG's Avatar
Default Re: str tb ....sticky and stiff throttle??? (Drag_Racer_DRU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU &raquo;</TD></TR><TR><TD CLASS="quote">mine works great... try adjusting your throttle cable, thats what i did and its perfect</TD></TR></TABLE>
did that solve the stickyness problem?or the hard as fawk pedal pressure problem?
Old Dec 23, 2003 | 01:57 AM
TREVER's Avatar
Check your cable. I thought it was my str tb that caused my sticking but it was the cable.
Old Dec 23, 2003 | 02:36 AM
00 FBP ItR's Avatar
Default Re: str tb ....sticky and stiff throttle??? (TREVER)
Well.. when I had my car...
It would stick on cold days, and i adjusted my cable ALL the way out.. it didn't really fix the problem.
I figured mine had a gsr throttle rotor instead of a b16/pr3 throttle rotor. Correct me if i'm wrong but, don't they make different rotors for each application.
Old Dec 23, 2003 | 05:44 AM
Tbone's Avatar
The return spring is alot stiffer on it so yes when you press the gas it requires alot more effort. They do this to keep it from sticking..... go figure. My Ericks requires more pressure than stock as well. Thats my only gripe about it.
Old Dec 23, 2003 | 08:51 PM
H22ek4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have this problem..is this normal??the throttle is hard as fawk, compared too stock..and the spring seems a lil sticky</TD></TR></TABLE>
With the str tb, my gas pedal is almost stiff as my clutch.
Old Dec 23, 2003 | 10:23 PM
Propulsion's Avatar
Default Re: str tb ....sticky and stiff throttle??? (H22ek4)
I don't know about you guys, but I personally perfer a stiffer throttle, feels like Im somehow "helping" the engine's effort when I dip into full throttle...LOL maybe Im just weird
Old Dec 24, 2003 | 02:11 PM
Junkiii Ek's Avatar
i have a problem with it also...same thing as urs ...i jus sold it ...went back to stock.... but its better than stocks.......
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
andlude
Nov 9, 2005 08:35 PM
rolledthatho
Sep 9, 2005 10:29 AM
