Help. stripped bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">craftsman bolt out
Well if you dont want to spend too much on those craftmen bolt out set. I recommend buying a vice grip it should get ahold of a stripped bolt.
</TD></TR></TABLE>Well if you dont want to spend too much on those craftmen bolt out set. I recommend buying a vice grip it should get ahold of a stripped bolt.
or hammer on a smaller socket you can replace or dispose of..
or cut the head off with a dremel and drill it out..
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Depending on where it's located and how easily accessible the bolt is, look for a (for lack of a better term) "nut cutter/splitter" You wrench it over the bolt and it cuts the nut. It worked on my cat when I stripped one of the bolts on the flange part.
you said a 14mm was to big and a 13mm was to small, have you tried an american sized wrench on the sucker?
This has worked for me in a couple of situations.
thanks guys for your help. i think im gonna try the torch and the bolt out. standard didnt work. its on a caliper actually. i have a type r and a galant gtz and its the galant. sucks **** is on tigter than any bolt i ever encountered
those work great, i got a set and had to use thme on a stripped Timing belt tensioner bolt. worked like a charm .
</TD></TR></TABLE>those work great, i got a set and had to use thme on a stripped Timing belt tensioner bolt. worked like a charm .
eg686
May 17, 2005 03:20 PM
