Leaky distributor
Old Dec 22, 2003 | 01:45 PM
porsche997dc2's Avatar
Default Leaky distributor
Does anyone have oil leaking internally from the distributor? I believe there is a oil seal from the inside of the distributor housing. Has anyone replace it before?
Modified by porsche997 at 6:15 PM 12/22/2003
Old Dec 22, 2003 | 08:11 PM
rtype11's Avatar
Default Re: Leaky distributor (porsche997)
dont believe it is a servicable part, just bad luck, sure the dist.. is mounted flush and appropriately torqued!
Old Dec 22, 2003 | 08:32 PM
95 integra's Avatar
Default Re: Leaky distributor (rtype11)
Ive replaced the o-ring on the distrubutor on my LS(SE actually). Anyway, it leaks around the distrubutor...its just an o-ring. You simply take the 3 screws out and pop the dist. off(a little oil will leak out(not much)) and then replace the o-ring and pop it back in. BTW, make sure to mark where your dist was so that the timing wont be off.
Old Dec 22, 2003 | 08:49 PM
Default Re: Leaky distributor (95 integra)
I know it's not the o-ring. Inside the distributor housing, there's an oil seal that keep the oil from going into the distributor when the distributor shaft is spinning.
Cameron k.
60
Sep 25, 2012 07:19 PM
jchrm80
May 17, 2009 09:27 AM
blackmfoggie
Aug 23, 2007 12:09 PM
s2kkid
Dec 12, 2005 06:42 AM
porsche997dc2
Dec 22, 2003 05:14 PM
