ZC motor with OEM CRX hood
Old Sep 23, 2001 | 01:36 PM
l0p3z's Avatar
Default ZC motor with OEM CRX hood
I've heard that the ZC motor has that cam plastic housing around it, that can pose a problem when you try to close your hood. Is there a way around this? Other than buying the ZC hood? Can't you just remove the plastic housing (revealing your cams)? And if you do this, is it safe? Thanks for any input!
Old Sep 23, 2001 | 01:57 PM
Cereal_Killer's Avatar
Default Re: ZC motor with OEM CRX hood (gCboY)
well you can just take the timing cover off but you run the risk of gettign stuff to fall in that crevace that is no longer protected. and believe me stuff does get down there, i learned theis after a new timign belt. i had a small rock fall in mine and throw my timing off. so you have 2 options take the cover off and run that risk, or just leave it on. the motor really doesnt rub on the hood that bad, it should be fine.
Old Sep 23, 2001 | 03:33 PM
crx(gator)'s Avatar
my hood closes just fine with the ZC and the protective cover on the timing belt too...
Old Sep 23, 2001 | 05:03 PM
l0p3z's Avatar
thanks a lot...
Old Sep 23, 2001 | 05:28 PM
Denny317's Avatar
hmmm....the motor should clear the hood just fine... you should remove that inner piece of the hood if you want to be on the safe side.
Old Sep 23, 2001 | 06:40 PM
gutted spec's Avatar
New User
Default Re: ZC motor with OEM CRX hood (Turbo Denny)
Well, I'm not going to make a post for this...but when I get the B20 block under my B16 head, what should I do about a hood? My hood already touches the B16 head in a small spot. Is there an SiR-style bulged CF hood or fiberglass hood that fits the usdm headlights (or my ef7 headlights)?
Old Sep 23, 2001 | 06:57 PM
l0p3z's Avatar
Default Re: ZC motor with OEM CRX hood (realdealb16)
Well.. there is a JDM hood for sale at Redshift at http://www.redshift.ca/ for $293
or a CF hood with a bulged.... for $550
hope that helps
Old Sep 23, 2001 | 07:04 PM
crx(gator)'s Avatar
Fiber images makes the Si-R hood for USDM headlights...
Old Sep 23, 2001 | 10:15 PM
dustin's Avatar
Default Re: ZC motor with OEM CRX hood (crxgator)
My ZC motor clears the hood. If it hits a little, just put some washers in between on the driver's side engine mount.
Dustin
spikehead221
Apr 2, 2008 12:05 PM
drewboy
13
Jan 11, 2006 01:56 PM
crxzcracer
Apr 1, 2004 02:05 PM
t0eKnEe
10
Nov 16, 2003 08:26 AM
JackAcc
16
Jul 13, 2003 02:04 PM
