H22 Type-S pistons in F22 VTEC motor?
Old Dec 22, 2003 | 10:06 AM
Aero Deck's Avatar
Default H22 Type-S pistons in F22 VTEC motor?
Is it possible to use H22 pistons in an F22 VTEC motor? Also, will the H22 valve springs work in an F22 VTEC head?
Old Dec 22, 2003 | 11:02 AM
KTeller8's Avatar
Default Re: H22 Type-S pistons in F22 VTEC motor? (DAsicks)
i think that h22 springs are dual springs.. and f22 are not.. also think something bout height comes in a factor
id personlly just get f22 valvetrain
Old Dec 23, 2003 | 05:36 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAsicks &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to use H22 pistons in an F22 VTEC motor? Also, will the H22 valve springs work in an F22 VTEC head?</TD></TR></TABLE>
no and no
Old Dec 23, 2003 | 08:12 AM
Nick H's Avatar
New User
Default Re: H22 Type-S pistons in F22 VTEC motor? (Mikey3000)
you'd have to bore out the f22 sleeves at least 2mm to get the h22 pistons to work in the f22, which isn't impossible....there are companies that make aftermarket pistons for the f22 though...
Old Dec 23, 2003 | 12:34 PM
im done's Avatar
Default Re: H22 Type-S pistons in F22 VTEC motor? (Nick H)
what companies?&gt;
Old Dec 24, 2003 | 07:32 PM
RABBIT9's Avatar
Default Re: H22 Type-S pistons in F22 VTEC motor? (imc2pid)
Race Engineering has pistons for the Honda F-series in either the stock 8.8:1 CR or 11:1 CR. The pistons are made by Wiseco, and run around $350 for the set if I remember right. I'm running the 11:1's with good results.
forcefedh22
Feb 27, 2005 04:54 PM
Power Rev Racing
Sep 30, 2004 05:09 AM
ratherbewalking
Dec 16, 2002 10:11 AM
