Help me to find a blueprint/drawing of a headgasket on H22A
i realy doubt you will find anyone with that, expecially a h22 head gasket, and you said h22a so im assuming your block is jdm closed deck? you best and probably only bet it going to either buy a head gasket and copy off of that, or trace off of the head/block to get the shape
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragge_c »</TD></TR><TR><TD CLASS="quote">going to cut out a new headgasket in cupper, anyone who have a blueprint/drawing ? (autocad) *.dxf *.dwg
best regards Ragnar</TD></TR></TABLE>
that's pretty cool
that's pretty cool
told you man , you will be hard pressed to find someone with a blue print. either your going to have to trace it yourslef onto the copper, or you are going to have to scan it , and then use cad to import the dimentions.
</TD></TR></TABLE>told you man , you will be hard pressed to find someone with a blue print. either your going to have to trace it yourslef onto the copper, or you are going to have to scan it , and then use cad to import the dimentions.
