roll cage weight???
Any one know how much a mild steel 8pt cage would way??? I wanna save weight by using some fiberglass doors but I dont want to leave my self volnerable to a t-bone. But its obviously not worth to do either(weight saving standpoint) if its going to end up waying just as much as stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoShoes »</TD></TR><TR><TD CLASS="quote">What IS the weight difference between a mild steel and chromeoly cage, assuming both are built to current NHRA specs?</TD></TR></TABLE>
Im wondering too....anyone??
Mild steel is almost double the weight of Chromoly ,,
Say if steel is like 9 lbs per foot for the legal stuff ,, 1 3/4 .118 wall thickness
Moly will be about 4 1/2 lbs per foot at the legal 1 5/8 .083 wall thickness ..
You can read about the wall thickness on the NHRA rule book .. But it's so much better , just a little more in prices .. But it's worth it .
Modified by lovitalracer at 10:15 PM 12/22/2003
has anyone ever weighed there doors?? say for example ef civic door??? Because im not fast enough to need a cage but if like I said if I go fiberglass doors and cage and end up weighing the same amount Im thinking its not worth it.
You can't look at it that way ,, I know one door is even hard for one person to pick up .. So just imagine two ... If you go with the 5 or 6 point roll bar it should only weigh like 40 lbs if that .. It's also way safer too .. to go with the roll bars ..
yea I guess. safety first and the cage would stiffen up my suspension alittle. safety>performance. But has anyone ever weighed there doors? I still wanna know. Where can I pick up a 5-6pt cage??? also does it cross where the door is?? because mainly I am afraid of getting t-boned with fiberglass doors. Unfortuneatly I have to drive this car everyday.
My rollcage added 37kg(82lbs) to my car but I got that back by removing the AC, removing the rear seats (needed for the installation anyway) and by replacing the heavy *** front seats with Carbon Kevlar FD3S RX-7 R1 seats. The driver's seat in the pictures is waiting for it's new owner to pick it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovitalracer »</TD></TR><TR><TD CLASS="quote"> Mild steel is almost double the weight of Chromoly ,,
Modified by lovitalracer at 10:15 PM 12/22/2003</TD></TR></TABLE>
1 5/8 x .083 moly weighs 1.367 pounds per foot - 1 3/4 x .118 mild weighs 2.089 pounds per foot
atermizi
Feb 18, 2004 12:37 PM
