Can I keep my intake resonator in with a short ram intake????
Old Dec 21, 2003 | 02:36 PM
integraautox's Avatar
Default Can I keep my intake resonator in with a short ram intake????
Ok I am either going to purchase a aem short ram intake or powercore short ram intake w/ heat sheild. I want to be able to keep the intake resonator in place and not have to remove it b/c the dealerships around here will void certain warranties with an intake so i want to be able to swap the intake back to stock in a timely fashion. With the short ram intakes can I keep the resonator in place. If not is it hard to take out / put back in the intake resonator. Thanks in advance.
Old Dec 21, 2003 | 04:49 PM
phatboy555's Avatar
imo, the stock resonator will cut flow to your sri...there's an cheap intake mod where you cut slits into the stock box just to improve air flow...so i suppose you could work your way around the box and keep it there, but your sri woun't be working at optimum levels
and since you have a sri, it doesn't take more than a few mins to replace the stock airbox
Old Dec 22, 2003 | 01:12 PM
mister x's Avatar
Default Re: (phatboy555)
Don't know about Powercore, but with AEM, the SRI connects to the throttle body. Neuspeed "P-Flo" SRI will do what you want, use the OEM air flow tube just replacing the OEM air box and snorkle. Think Super Street magazine tested it with a titanium cat back and got pretty good gains.
Old Dec 22, 2003 | 08:54 PM
ITR_1211's Avatar
Default Re: (mister x)
If you want to keep the noise level down, maybe go with a comptech icebox.
Old Dec 22, 2003 | 09:42 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: (Darryl Mussashi)
If you want to keep the noise down don't rice around town.
Plus as an added benefit you won't be visiting the service department in order for the warrany to be an issue for quite some time.
jr408
Feb 27, 2008 09:26 PM
power11
Jun 26, 2007 02:34 PM
katb16vo
Mar 18, 2004 06:55 PM
honda-man
Jul 3, 2003 05:00 AM
