skunk2 intake manifold idle problem, again
Old Dec 21, 2003 | 01:22 PM
ncVTEC1313's Avatar
Default skunk2 intake manifold idle problem, again
i cant figure out whats wrong with this thing. after the car warms up, the idle will go from around 2000, drop down to about 900-1000 and then go back to around 2000 and it will continually do this. after i installed the manifold, i didnt have an intake that worked, so i just ran it without one, but this has only started since i put the cold air on that i got. there are no vacuum leaks that i can find, the ecu has been reset, and im just out of ideas. anyone have any thoughts?
Adam
Old Dec 21, 2003 | 05:01 PM
TurBoTeG's Avatar
Default Re: skunk2 intake manifold idle problem, again (ncVTEC1313)
you probably got your IACV dirty when you swaped it over...its on the back of the manifold with coolant lines running to it...take it off and clean it out
Old Dec 21, 2003 | 08:56 PM
99silverbullet's Avatar
Default Re: skunk2 intake manifold idle problem, again (TurBoTeG)
That's what happened to me, and that's what I did and problem solved I used sensor safe carb cleaner.
Old Dec 22, 2003 | 01:49 AM
Sukebei Oni's Avatar
if it happens when the car warms up, you might have air in the cooling system. i've seen an accord do that after installing a water pump. once we burped the cooling system the idle returned to normal.
97ej6dx
Nov 27, 2010 08:57 AM
DVPTeG
Jun 29, 2007 11:26 AM
iukaman420
May 4, 2005 02:56 PM
duberz
Oct 14, 2004 03:03 PM
Lysawy
Dec 10, 2002 04:46 PM
