OT: ITR Mugen Rear Swaybar (26mm) ??
Just wanted to find out from those who had bought the Mugen rear Swaybar. What comes with it? The bar, D-Bushings, and D-Brackets?
And does it come with new endlinks, or do I end up re-using them?
When I had the Civic, I bought one and it came with bushings and two frame stiffener pieces of metal. The bushings are made to fit under the stock brackets. On the ITR you either won't get the stiffener pieces or you won't need them, I'm pretty sure I remember reading that somewhere. No end links either. Good Luck.
Jeremy
Jeremy
Dangit! The bar came in today.. Why can't I ever have an easy install? The bar didn't come fully assembled. I spent 30 minutes trying to figure out how to press the bushings into the teenie tiny hole in the ends of the bar. Grr. Tried my hands, a clamp, and finally some pliers. The pliers did the job, but it was still difficult.
After that, it was a breeze to install. The car turns in so much nicer now that its almost scarey
Now I just have to wait until Oct 7th to really try it out.
Its all in the sig.. its all in the sig..
I still don't have those nifty Mugen socks that EPGONZALEZ has...
[Modified by arren123, 6:16 PM 9/26/2001]
98TYPER300, yep!! You were absolutely right..
I took the car to an empty parking lot behind a building and I was amazed. No matter how much I turned the wheel, the car kept on turning. Heck, I put it to full lock and hit the gas and I didn't still didn't get any understeer. Of course I wasn't going that fast.. Can't wait till autox to explore the new limits.
On a side-note, I was a little perplexed at how flimsy the endlinks are.. How come they don't break?
this might have been covered before but here it goes....with the whole mugen setup..like f/r strut tower bars...and sway bars, NOT including the dampers or lowdowns, what would it overall give you? oversteer understeer neutral?
....with the whole mugen setup...NOT including the...lowdowns...oversteer understeer neutral?
Mattj
Those socks look like a big orange foreskin on the master cylinder. HAHA.
Hey, any of you guys try this(it's cheaper than a Mugen bar)...
install a 22mm front LS swaybar. Then inflate your rear tires 5psi more than your fronts. Pretty nice setup. did it on mine. makes a sweet difference.
Dam... now everybody knows...
Oh well.. I guess the orders for LS bars just went up by a factor of 10. Will
-who likes rear-end rotation.
dc2jdmhonda, Mugen Lowdowns are plug-n-play. They just drop right in if you're an experienced mechanic. Or if you're like me, it will take a good amount of time.
Yep, the LS swaybar trick is a good one, or so I've heard. But what's the tradeoff for running 5psi more in the rear?
Way OT but I just noticed that the Socks on the resivours on that car are not installed right, they are sticking up to much.
Mattj
dude.. i must be a complete idiot..does anyone have instructions for installing socks?
they come with a rubber o-ring on top to fold over all excess material..
Mattj
yes...alot more responsive...i ran with just the rear for awhile.me..being a novice had trouble controlling the oversteer at higher speeds..especially freeway on ramps..with the front on..it became a little more predictable for me..
oops..i see just saw strut bar...no difference at all
[Modified by EPGONZALEZ, 11:20 PM 9/27/2001]
