problems with alignment after putting on tein ss coilovers
Old Dec 21, 2003 | 10:16 AM
fireDC5's Avatar
Default problems with alignment after putting on tein ss coilovers
I will try to explain the problem best as i can
On monday i tried to install my coilovers myself and i was trying to separate the tie rod end from the stock struts/shocks by using a hammer to hit the bottom. This mishaped the threads so the nut wouldnt go on, so i had to get a new tire rod end but the alignment was off.
On tuesday coming back from my work i turned onto an onramp onto i55 @ like 15 mph and there was some black ice on the road and i slid into the curb front right tire first.
on wednesday i took it to my friends shop and he installed the coilovers and the alignment was very off pushing to the right.
On saturday i took it to get aligned and they said that they couldnt go it because the inner tie rod ran out of thread so the toe couldnt be adjusted to zero.
I took it to another shop and they said that the tie rod was maxed out but they thought that the inner tie rod was screwed in too far so they tried to screw it further in. im not too sure if they knew exactly how to do it but it got a bit better, then they adjusted the camber a bit from the top so toe got better but the camber was a bit off.
Also the right back wheel has like -2.1 camber.
Right now my car is pulling very slightly to the right. Is this because of the negative camber in the back or could it be because of something happening like a bent frame when i hit the curb....???
thx
Old Dec 21, 2003 | 11:49 AM
96 Ls lnTeG's Avatar
what camber kit?? are you running????
Old Dec 22, 2003 | 06:05 AM
fireDC5's Avatar
the SS come with camber kit in the front, i have no camber kit in the rear however. It is on my to buy list
AMPLAYOEP3
Suspension & Brakes
Mar 28, 2018 10:15 PM
sdctitans
Honda Civic (2001 - 2005)
Sep 12, 2007 02:45 AM
arsim
Suspension & Brakes
Sep 4, 2007 07:34 AM
fg2si!kid
33
Dec 5, 2006 04:35 PM
fireDC5
Jun 6, 2004 01:35 PM
