I know si axles will work with a dx but..........
Old Dec 20, 2003 | 11:27 PM
Red_Si's Avatar
Default I know si axles will work with a dx but..........
will si axles work with a 91 std hatch??? i think i may have mistaken my hatch for a dx and i think it may actually be a std. will the si axles still fit?
Old Dec 21, 2003 | 06:56 AM
kid-honda's Avatar
I believe the STD is like the HF and the hubs need to be replaced.
Old Dec 21, 2003 | 07:12 AM
JackAcc's Avatar
Default Re: (kid-honda)
Yes, I have the STD and I had to replace the hubs and axles when I put in the Si trans.
Old Dec 21, 2003 | 07:21 AM
phatrick2332's Avatar
you shouldnt have to replace the axels when u put an si trans into a std car. The inner side of the axels are the same, just the outers are different, all dseries trannies have the same size openings for the axels.
Old Dec 21, 2003 | 08:26 AM
91civicDXdude's Avatar
Default Re: (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">you shouldnt have to replace the axels when u put an si trans into a std car. The inner side of the axels are the same, just the outers are different, all dseries trannies have the same size openings for the axels.</TD></TR></TABLE>
you are correct with one exception. the ZC tranny. It has the bigger tranny recepticales like a B series, and this is why you use the 90-93 teg axles with the ZC tranny.
Old Dec 21, 2003 | 09:10 AM
Red_Si's Avatar
Default Re: (91civicDXdude)
so if i did a swap with a d16a6 into my std, could i just re-use the axles its currently using??? just not use the si axles b/c the outer part won't fit?
Old Dec 21, 2003 | 09:12 AM
bossman032's Avatar
Default Re: I know si axles will work with a dx but.......... (Red_Si)
when doing a swap like a b16a or whatever b series upgrade the brakes
GSR or LS good stoping power
Old Dec 21, 2003 | 09:34 AM
yes when u put an a6 in u can use your old axels.
Old Dec 21, 2003 | 10:41 AM
buckNasty's Avatar
ok so u can use the axels and still not change the hubs right?
Old Dec 21, 2003 | 08:58 PM
you can use your std axels and hubs on an si tranny (aka a6 tranny aka, any dseries tranny known to man besides the zc apparently lol)
Old Dec 21, 2003 | 09:08 PM
Red_Si's Avatar
good to know
Old Dec 21, 2003 | 09:54 PM
buckNasty's Avatar
Default Re: (Red_Si)
yeah thanks for the info
dynamitezz
15
Aug 14, 2010 10:25 AM
LurkerS8
17
Jun 25, 2005 07:46 AM
gutted-dx
Mar 4, 2005 10:04 AM
Civicboy
23
Jun 28, 2002 09:26 AM
carsaregood
Feb 5, 2002 09:05 PM
