Rev Limit: B18C1 w/ ITR cams/valvetrain, PR3
I'm sure this is a repost, but its a pretty simple question...
(1) How high can a GSR engine with ITR/CTR cams and valvetrain and PR3 pistons go?
(2) What's it take to get a GSR engine to rev to the same rate as an ITR engine?
Reliably
Thanks
Ben
Reliably
Thanks
Ben
Most folks say the ITR valve train is good to about 9k. Some even say as high as 9200, but I wouldn't trust it. If you are running ITR/CTR cams, they don't make power past 8600, so reving higher would not be very beneficial. The stock bottom end should be able to handle that just fine.
Other than that all it takes is a chipped ECU, or some other external computer to raise the rev limiter.
Acura97GSR
Jul 12, 2001 11:23 PM
