92-97 H22 block and 98+ H22 block differences
Hey guys, does anyone know the difference in the main journal sizes from these two blocks???? What's the size of each??
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">Theres no difference between the 97-01 Prelude blocks</TD></TR></TABLE>
Actually, guys. There is a difference. Do a search on http://www.hondaautomotiveparts.com and you will see. It just doesn't have the spec. on each block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse »</TD></TR><TR><TD CLASS="quote">93-97 Blocks use 50mm main bearings,
98-01 Blocks use 55mm mains.
SOME 98 blocks supposedly have the 50mm mains.</TD></TR></TABLE>
THANK YOU!!! This is what I was looking for.
Now i have one more question. What is the difference between the 92-97 H22 crank and the 98-2001 crank?? Is it, too, larger in diameter??
Thank you all for your help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinger »</TD></TR><TR><TD CLASS="quote">isnt there open deck 92-96 blocks also?</TD></TR></TABLE>
i thought they might of had an open deck 96 block too
yeah the 92-97 have 50mm mains, and the 92-96 is closed deck, the 97 is open deck, and the 98+ have beefer mains and have a 55mm bore, and the are open deck as well. the 92-97 cranks just have like 49.xx mm crank journals, and the 98+ have 54.xx mm crank journals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">yeah the 92-97 have 50mm mains, and the 92-96 is closed deck, the 97 is open deck, and the 98+ have beefer mains and have a 55mm bore, and the are open deck as well. the 92-97 cranks just have like 49.xx mm crank journals, and the 98+ have 54.xx mm crank journals.</TD></TR></TABLE>
Thanks, Tom.
Thanks, Tom.
h224thgensedan
17
Mar 29, 2008 07:09 PM
