Honda S2000 Honda S2000
Dynoplot for the New T1R exhaust
Old Dec 20, 2003 | 05:47 PM
AJ PwR's Avatar
Default Dynoplot for the New T1R exhaust
Hi guys,
Just got the my car dyno today.
Base line settings
-Mugen intake
-T1R header
-Stock exhaust and cat
VS
-Mugen intake
-T1R header
-T1R Sport exhaust with test pipe
I was surprised with the gains I was expecting about 7-8whp and finally come up with a good 12whp at peak and the low end and mid-range has signicantly improved.
Enjoy
Thanks
Ben
Modified by AJ PwR at 11:23 AM 12/23/2003
Old Dec 20, 2003 | 06:20 PM
Willard's Avatar
Default Re: Dynoplot for the New T1R exhaust (AJ PwR)
quite a difference in the a/f reading.
looks good.
Old Dec 20, 2003 | 09:23 PM
Mase's Avatar
wow, the afr change is quite large.
I think the reason u saw that much gain is because its running that much leaner.
Old Dec 20, 2003 | 10:22 PM
JL9000's Avatar
Default Re: Dynoplot for the New T1R exhaust (Mase)
The A/F ratio is near perfect for NA F20Cs.
Old Dec 20, 2003 | 10:34 PM
NA gs-R 05 C
Guest
Posts: n/a
whoa, that's some good gains. T1R
Old Dec 21, 2003 | 06:32 AM
strepto's Avatar
Default Re: Dynoplot for the New T1R exhaust (NA gs-R 05 C)
Does this mean AJ finally got the T1R shipment - and have everything in stock now, including my system?
A "yes" would be the best xmas present I could ever have!
Old Dec 21, 2003 | 07:52 AM
Chris93Si's Avatar
That's a very impressive gain, any photos on the car?
Old Dec 23, 2003 | 10:22 AM
AJ PwR's Avatar
Default Re: Dynoplot for the New T1R exhaust (Chris93Si)
Yes I did received a shipment just recently but I will have another one coming after new year. IM me what you want and I can give you the availability on them.
Old Jan 6, 2004 | 04:52 PM
Project SSAP1's Avatar
back to life...what is the price for the exhaust system...and is there a T1R test pipe that can be added the equation???? also any pics of the header??
also what is the weight of this system??
Modified by Project SSAP1 at 9:32 PM 1/13/2004
Old Jan 6, 2004 | 05:56 PM
NA-C5's Avatar
Default Re: Dynoplot for the New T1R exhaust (Project SSAP1)
There's just one problem. The *** end of your S2 looks a little lonely but hey for the gains it puts down what the hell.
Old Jan 6, 2004 | 07:59 PM
evil vapor's Avatar
Default Re: Dynoplot for the New T1R exhaust (JL9000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL9000 &raquo;</TD></TR><TR><TD CLASS="quote">The A/F ratio is near perfect for NA F20Cs.</TD></TR></TABLE>
that's a bold statement to make, it varies with different setups and conditions
Old Jan 6, 2004 | 09:18 PM
strepto's Avatar
Default Re: Dynoplot for the New T1R exhaust (vapor)
I hope my system ships soon. still waiting for an order confirmation..
Old Jan 12, 2004 | 08:45 PM
OC 335i's Avatar
Just curious, how noisy is this exhaust? Any comparisons?
Old Jan 13, 2004 | 08:11 AM
glagola1's Avatar
Default Re: Dynoplot for the New T1R exhaust (JMS JT)
Man, that looks like an expensive why to lean out your a/f. I would love to know what you would see if you richened it up again.
Does anybody know the results of a simple vafc tuning on a stock S2k?
Edit: Whoa, forget all that I said. I did some searching and found that those are pretty good gains! Rock on.
Modified by glagola1 at 5:43 PM 1/13/2004
Old Jan 15, 2004 | 10:38 PM
OC 335i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMS JT &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, how noisy is this exhaust? Any comparisons?</TD></TR></TABLE>
Okay I found the answer on S2ki.com
FYI -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ PWR &raquo;</TD></TR><TR><TD CLASS="quote">From 1000-3000rpm, the Mugen seems to have better acceleration, however starting at 4000rpm with the T1R exhaust the car pulls a lot stronger. VTEC pull from 6000-9000 , it's a night and day difference !!! I thought my car is one of the weakest built F20C, but now I feel that my car has much more power, so it doesn't seem like it anymore.
Soundwise, the T1R is much louder than the Mugen but quieter then Spoon , J's or Buddyclub. With the silencer, it sounded so much quiet like Mugen.
Here's some pics for it.
The T1R system weight only 29 lbs including b-pipe , test pipe and muffler. Very decent IMO.</TD></TR></TABLE>
Old Jan 16, 2004 | 08:35 AM
Bs2kB6
Guest
Posts: n/a
how much does this exhaust run for? how many lbs is the mugen one? does it only come with one? or can you have a dual? and if its dual will you lose power compared to the single?
Old Jan 16, 2004 | 08:37 AM
Bs2kB6
Guest
Posts: n/a
any more pics of your car AJ? looks clean.
Old Feb 5, 2004 | 08:34 PM
xtremecivichb's Avatar
Default Re: Dynoplot for the New T1R exhaust (Bs2kB6)
Nice #...
JackBurton
May 17, 2007 09:27 AM
AJ PwR
Honda S2000
27
Dec 18, 2004 01:25 PM
jfingers
Mar 26, 2004 09:03 PM
jji106
Dec 22, 2002 07:17 PM
braweebsta
Oct 25, 2001 10:17 PM
