Engine operating/water temp
Old Dec 20, 2003 | 05:41 PM
theseus824's Avatar
Default Engine operating/water temp
I have made several datalogs with my Hondata and my water temp never goes above 165degF. How am I supposed to tune if the engine is always adding cold fuel enrichment? Is there something I can do? I'm think maybe my thermostat is faulty. I have a Turbo B18B fully built and sleeved and a C&R Racing radiator. Any help or suggestions would be appreciated.
Old Dec 20, 2003 | 07:19 PM
omega11855's Avatar
you could put a higher temp thermo in there that would def be the first step
Old Dec 21, 2003 | 07:37 AM
blah13's Avatar
Default Re: (omega11855)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omega11855 &raquo;</TD></TR><TR><TD CLASS="quote">you could put a higher temp thermo in there that would def be the first step</TD></TR></TABLE>
Yup, so it wont open the thermo till it hits a higher temp than what the one you have now is set at. Sounds like you've got too much coolin power......or a faulty thermo
Old Dec 21, 2003 | 01:07 PM
2+2=5's Avatar
Default Re: (blah13)
check the thermostat..looks like that's the problem there.
thremo stay open for too long, coolant flow too fast and never really have enough time to carry the heat to the radiator.
btw, how acturate is hondata's info? compare to pad(with obd2 equiped car?)
primetime
Aug 22, 2010 07:00 PM
alexthegrinch
Oct 9, 2008 11:02 PM
mike93eh
Sep 14, 2005 02:41 PM
kenzieambrose
May 27, 2005 05:31 PM
