avg. going rate on the 5th gen timing belt change...@ dealer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">$800.00 </TD></TR></TABLE>
Yeah, that was the main reason why I decided to do the H22 swap. Kill two birds with one stone.
Don't forget to get your water pump changed while you are at it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dankbudz11357 »</TD></TR><TR><TD CLASS="quote">did you replace the timing belt on the h22 that you swapped in? </TD></TR></TABLE>
Yes, that along with the water pump will be changed. I will also convert my H22 to a manual timing belt tensioner. I am having the piston rings and possibly the main and rod bearings changed too. I am trying to do it right the first time.
I was hoping to get the H22 swap before I had to get my clutch changed on my current H23. It was preventing me from driving it so I had to change it. That would have been another $700 that I didn't have to waste.
Oh well, at least i got to see how the H23 performs on the track for one season. There was one turn that I couldn't go faster because I had to drive though it at redline. The H22 will be nice since I will have an extra 1000 rpms to play with and more HP.
