What timing belt?
I did a search for timing belt and came up with a lot of topics, but there wasn't much on what timing belt to get, just mostly problems about the timing belt. So.. i made this thread.
My questions is what timing belt should i go with? OEM? or Aftermarket? I need something that's going to be reliable, cant afford for something to go wrong. I was looking into this belt http://www.boomplustoys.net/pwrent_engine.shtml anyone got any idea if these are any good?
Btw.. it's going on a B16A2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I need something that's going to be reliable, cant afford for something to go wrong.</TD></TR></TABLE>
PE or Toda.
PE or Toda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunz »</TD></TR><TR><TD CLASS="quote">what happend?</TD></TR></TABLE>
What happened? nothing.. just going to be changing to some more aggresive ones(01 ITR cams, w/ Spoon Gen 2 gears), and so; while i'm in there.. i might aswell change the timing belt and water pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 »</TD></TR><TR><TD CLASS="quote">OEM
OEM......for all your basic replacement (wear and tare) parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">hehe' i went with the good ole BF Goodrich Gator belt from Autozone'
heh... only thing i could get at 1030pm needing to work the next morning'</TD></TR></TABLE>haah.. nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">
OEM......for all your basic replacement (wear and tare) parts.</TD></TR></TABLE>
So even if you raise the red line above what stock is the OE belt will still be sufficient? Wouldn't want the motor to fail at a critical moment b/c of a belt problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostySol »</TD></TR><TR><TD CLASS="quote">
Gonna go with OEM then. thanks
</TD></TR></TABLE>Gonna go with OEM then. thanks
Yes the OEM timing belt will take the punishment. But since you're also installing a new water pump, I wouldn't just jump right in and gun it and rev real high for a little while. That way the new parts can get broken in. Know what I'm sayin'?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xavior66 »</TD></TR><TR><TD CLASS="quote">Yes the OEM timing belt will take the punishment. But since you're also installing a new water pump, I wouldn't just jump right in and gun it and rev real high for a little while. That way the new parts can get broken in. Know what I'm sayin'?</TD></TR></TABLE>
Yah. I'm planning on driving it around for probably a good 50-100 miles before i get it tuned (which will require to rev high).
bet_88
Sep 7, 2006 02:49 PM
