Engine light on and stays on til I turn car off and back on - 93 JDM Lude
Old Dec 20, 2003 | 02:47 PM
ProjectLude93's Avatar
Default Engine light on and stays on til I turn car off and back on - 93 JDM Lude
C'mon all,
Someone has to have an idea here......
Hi all,
I am having a problem with my 93 Lude. She has a 93 JDM H22a swap. sometimes when I hit a bump or when I have a hard launch, a check engine light comes on.
After the light comes on the car runs rough up to 6,000 RPM then doesn't go any higher on the RPMs. It also idles rough too. My VTEC usually kicks in at 6,000 RPM.
Could this be the VTEC solonoid since my RPM's are being limited at 6g? If so, where is this located and how can I check to see if this is my problem, where does the harness connect into the VTEC solonoid?
I've tried shaking the wiring harness every possible place I can think of to recreate the check engine light but it never triggers it. Only happens on bumps or hard launches.
Thanks........
Modified by ProjectLude93 at 2:00 AM 12/21/2003
famdakam
Apr 12, 2018 09:24 PM
KILLAB17VTEC
Aug 13, 2010 04:21 AM
schpootypie
Feb 26, 2006 09:17 AM
egcivic
Jan 14, 2006 07:51 AM
