H23 with H22 VTEC head - how to and expected power rating?
Hello all,
I am working on a frankenstien motor. It is a 92 H23a with 80k and I have a USDM 93 VTEC head with JDM Type S cams with new cam seals and 40k on the head. I heard there you can't just slap this head on the H23a but I can't find any info on how to do this properly.
Also, what horspower and torque can I expect from this combo. The H23a had 160hp, and a 93 VTEC is rated at 190hp. I am guessing I can get 240 hp with headers and cold air intake. I am also thinking of putting a VENOM intake on here too but I might save it for my 93 JDM Lude.
Also, are the H23a intake manifolds and the H22a manifolds the same?
Any help is appreciated, especially on the head change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectLude93 »</TD></TR><TR><TD CLASS="quote">Hello all,
I am working on a frankenstien motor. I am guessing I can get 240 hp with headers and cold air intake. </TD></TR></TABLE>
man if it was only that easy
read through this thread and then see
what questions you have after that
https://honda-tech.com/zerothread?id=510617
240 Hp, Dats all?...... You should easly be makeing 300Hp with dat H23Vtec
And save your Venom manny for da jaydeee-em lude.....
Thanks man.....that thread opened my eyes up a bit further. Think maybe I'll just dump the whole swap on Ebay for someone else to do. I don't want to sink that much time or cash into it.
Thanks to all others too but keep the info coming as I may do this in the spring when the weather is warmer and I have more time to dedicate.
Yeah, it is better to start with full H22 swap...and just buy the H23 block and crank.
I thought about doing the hybrid but there just is too much uncertainty. I would rather build up and H22 than make an H23VTEC.
Some say you can rev the hybrid as high as a regular H22, however, others say that you can't. I would rather go with the certainty because I can't justify spending too much money on this car.
Do some research before attempting it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">240 Hp, Dats all?...... You should easly be makeing 300Hp with dat H23Vtec
You are a stunna please /yourself.
</TD></TR></TABLE>You are a stunna please /yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 »</TD></TR><TR><TD CLASS="quote">
You are a stunna please /yourself.</TD></TR></TABLE>
No, your just a jackass.... And dont see the sarcasm in my post....
So please / yourself..
yea, the h22 ports are bigger
