Will B16B pistons fit in a B16A2....QUICK YES - OR - NO
I am rebuilding a b16a2 and I want to use CTR parts to build it up.
Will the B16B "JDM CTR OVERSIZED PISTONS" fit in the cylinder head of the B16A2?
What rods should I use in the combo, will CTR rods work if I am using the stock b16 crank?
This is a pic of pistons, hopefully it works:
What do you guys think?
the orginal rods will work also you just have to mill 1mm off each side of the top end of the rod so the pistons will fit on it!
CrazyKoreanCrx
Feb 26, 2004 01:45 PM
