H-22 swap
Old Dec 20, 2003 | 01:04 AM
Redek4's Avatar
Default H-22 swap
I got an automatic 97 accord I'm thinking about doing a H-22 swap in. What harness and etc would I need?
Old Dec 20, 2003 | 06:41 AM
arkytec's Avatar
click on search and type in H22, and you will find fifteen million threads that can possibly answer any potential H22 swap question...!
Old Dec 20, 2003 | 09:06 AM
TotalJDM.com's Avatar
Default Re: (arkytec)
The Search button is your best friend.
Let me know if you're looking for an auto H22A, I have plenty.
Andre
andre@total-boost.com
Old Dec 20, 2003 | 01:17 PM
KTeller8's Avatar
Default Re: (TotalBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TotalBoost &raquo;</TD></TR><TR><TD CLASS="quote">The Search button is your best friend.
Andre
andre@total-boost.com</TD></TR></TABLE>
yeah but your in a world of hurt.. i ll explain it all to you , if you want to chat..
but this is the facts..
obd2 sucks.. so you cant go obd1 cause your car now is wired and setup so that the tranny and ecu are run off the same ecu..
ok so the smart *** comments would be get a obd2-1 harness. well you cant do that unless you find someone, in which ive looked for 1.5yrs and i got one rare custom made $250 harness and i am not sure it is even correct and going to fix the problem. why? cause no one wants to do the time and researach to learn and see how to take one harness unit and split it to where the transmission runs off its own comptuer and ecu/car runs off another..
cause you need to split the tranny control unit and the ecu. cause obd1 would be two units or computers..
so you say, ill stick obd2.. wrong again.. why? cause there is NO H22 AUTO ecu's out there that are obd2... then you get ppl saying use 97+ auto.. wrong again.. why? cause 97+ has the immobilzer and if you get around that after $$$ you then are stuck with the fact that their trannys are auto/five speed short shifter...
if your for real bout doing a h22 in your car and its a 96-97 accord auto.. email me, ive dropped a ton of money, time and i have a 96 auto h22... i was ready for build and turbo and had it all here.. for over a year.. ive had bother but CEL's and troubles iwth the car, cause obd2-auto-h22 dont go well together...
email me and ill explain or help you out.. i got the harness here, but i never got to use it properly, cause you need an auto obd1 ecu and h22 tcu.. and there was more problems then than.
if you want to keep the auto.. do this.... h23 nonvtec.. cause you can use and find 96 h23 auto ecus.... or swap out the auto to five speed..... good luck, i also have one other way in mind.. but its top secert, till i test it!
you ask why do this? i wanted to be one of only the smallest handful of ppl in the world to have an auto h22 obd2 boosted , build accord.. and beat 80% of the five speed guys out there~! dreams and money.. well i have the dream not the bling!
Old Dec 20, 2003 | 08:33 PM
Redek4's Avatar
Default Re: (KTeller8)
Hey, thanx alot. very usefull info, I've got alot of thinking to do
Old Dec 20, 2003 | 09:32 PM
KTeller8's Avatar
Default Re: (Redek4)
just email me if you get anything fancy stirring in your head
scottytooshort
Aug 26, 2016 12:41 PM
prettylew
Jun 15, 2008 02:07 AM
Team Highway
Mar 25, 2007 09:42 AM
slitfill
Sep 27, 2005 06:25 PM
slow_95_accord
Sep 26, 2003 10:56 PM
