coilovers
Old Dec 19, 2003 | 11:57 PM
pho iz good's Avatar
Party Pooper
Default spring alignment caps
my coilover kits came in today and its missing "4 billet aluminum spring alignment caps" I Emailed the seller about it but he hasnt reply yet. My friend who is helpin me with the install said I dont need it...is this true??
Old Dec 20, 2003 | 12:02 AM
2+2=5's Avatar
Default Re: spring alignment caps (learningn00bie)
From the statement above i can tell you this
1)you got some cheap *** sleeve over spring
2)the billet bullshit is just another marketing name, do you really think they guy selling those would know what the heck is it?
post a link or a picture of the actual item, we'll start from there.
Old Dec 20, 2003 | 12:28 AM
Party Pooper
Default Re: spring alignment caps (2+2=5)
the silver circle cap with the hole in the middle
Old Dec 20, 2003 | 01:06 AM
2+2=5's Avatar
okay, punch your friend in the face now, the thing is needed of course, how the heck the strut gonna seat right with out the plate? running w/o on a uni-body car=bad idea.
swap them back it before it bend the shocks' rod
GOOOOd luck
Old Dec 20, 2003 | 07:40 PM
Party Pooper
anyone kno where I can find this part seperately?? Or some other part that will work?
Old Dec 20, 2003 | 08:25 PM
fluxion's Avatar
amin n'rangwa edanea
honestly i dont see why they would be needed. doesn't the top hat on a stock shock serve the same purpose? correct me if i'm wrong. i wouldn't advise not installing them the way they are designed to be, but it doesnt seem absolutely necessary if you cant locate the part.
more to the point, i have no idea where'd you would get the part by itself. contact the manufacturer.
Old Dec 21, 2003 | 10:49 AM
klassesports's Avatar
does the civic coilover will work on accord to?, because it works on integra . btw my car is 95 accord lx and the coilover is form 99 civic ferio
Old Dec 21, 2003 | 12:46 PM
2+2=5's Avatar
Default Re: (klassesports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klassesports &raquo;</TD></TR><TR><TD CLASS="quote">does the civic coilover will work on accord to?, because it works on integra . btw my car is 95 accord lx and the coilover is form 99 civic ferio</TD></TR></TABLE>
good hi jack dude, and to answer you q's, hell no, they are way way way too short.
Old Dec 21, 2003 | 11:53 PM
Party Pooper
Default Re: spring alignment caps (fluxion)
I was thinking the same but I havent tried using the stock top hat yet. Wouldnt the stock top hat be too big for it? Would it be safe using the stock top hat even IF it did fit???
Old Dec 22, 2003 | 06:10 AM
boonacka's Avatar
actually that aluminum top hat is not really necessary. the skunks never came with any. although i did order some top hats from ground control. they just help keep the spring aligned better. if you dont have em, it'll just make clanking sounds when you take turns fast because of the body roll and droop of the suspension. thats a common problem/pita with sleeve coilover kits. one solution is to get helper springs which i think aerospeed makes some. i dont know the quality but honestly i dont think it will be that great. another solution would be to get a shorter shaft shock such as the tanabe sustec shocks or those cheaper drop zone shocks (not recommended). if you can, just return those and get some koni yellows because they have the adjustable perch as well and some eibach or h&r springs. that will probably give you the best comfort as well as quality performance without going into a full bore coilover kit. good luck
dodt
Suspension & Brakes
Jul 26, 2015 07:58 PM
x1xofakindx
Suspension & Brakes
Mar 28, 2009 08:45 PM
mykeerocks
Honda Civic (2001 - 2005)
Mar 19, 2008 07:04 AM
jaydmcrx
Suspension & Brakes
13
Nov 9, 2005 02:32 AM
BanEL
Nov 19, 2002 10:07 PM
