CRX SI APEXI VTEC CONTROLLER QUESTION PLEASE HELP!!!!!!!!!!!!
Old Dec 19, 2003 | 11:25 PM
Frederz's Avatar
Default CRX SI APEXI VTEC CONTROLLER QUESTION PLEASE HELP!!!!!!!!!!!!
hey everyone, it seems to me that i have a problem....
i got a 1990 CRX Si with a d16z6 VTEC and i also have a APEXi VAFC but since my ecu is a non vtec how do i hook it up????? any help will be greatly apprecciated!!!
Old Dec 20, 2003 | 02:18 AM
PaImportTuner's Avatar
Default Re: CRX SI APEXI VTEC CONTROLLER QUESTION PLEASE HELP!!!!!!!!!!!! (Frederz)
Ok do you have the instructions?? go to apexi site (www.apexi-usa) unless it changed.. if your using stock d16a6 ecu(pm6) then your wiring diagram is H1-a.
Follow the diagram on page 12 [h1-a] connect everything to signal harness.. except the VTM and *Pressure. Then run a direct line from the vtec solenoid in engine bay to the v-afc unit(purple wire) there is no need to run the wire to ecu(which is pink wire.dont use or splice into). Now your done, will take 2 minutes to do that if wire is connected to selonoid and already through firewall.
*You dont need to splice the pressure wire for the v-afc to work, but it's good for a electronic boost gauge. If not FId then it just reads system vacumm.
Also I hope your soldering all the wires and using rubber caps and then elec tape it all up. Do it the right way.
gsrpedro
Dec 5, 2009 08:49 PM
_Endless_
Jun 26, 2003 03:57 AM
wildesh
Dec 6, 2002 07:18 PM
noricercrx
May 6, 2002 08:18 PM
