Cusco Cage In 96 Coupe?
Old Dec 19, 2003 | 10:00 PM
integlspwr2k's Avatar
Default Cusco Cage In 96 Coupe?
Does anyone know if Cusco makes a 6 point cage for the 96 civic coupe. I know that they make for the HB, but not sure if the HB application fits the coupe. So, with the cage, is it possible to have passengers sit in the back?
Thank in advance...
Old Dec 19, 2003 | 10:04 PM
DCStreetHtch's Avatar
Default Re: Cusco Cage In 96 Coupe? (integlspwr2k)
hit up "Airbagclub" with questions, he'll surely help you out if he can.
-Bryan-
Old Dec 20, 2003 | 06:21 PM
Default Re: Cusco Cage In 96 Coupe? (EGStreetHtch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGStreetHtch &raquo;</TD></TR><TR><TD CLASS="quote">hit up "Airbagclub" with questions, he'll surely help you out if he can.
-Bryan-</TD></TR></TABLE>
No user was found with that username.
Help ?
Old Dec 20, 2003 | 06:31 PM
Airbag Club's Avatar
here is one in my 99 hatchback...
the hatchback cage should fit in a coupe. i've seen it before in a 99 civic SI. one problem though, is that if you have a sunroof, then you would have to bang the floor of your car to make the cage fit. the reason for doing so is because the sunroof causes the roofline to sit about an inch lower, and since cusco cages are so roof hugging, it won't clear.
Old Dec 20, 2003 | 06:53 PM
shauniewalnuts's Avatar
Default Re: Cusco Cage In 96 Coupe? (Airbag Club)
that bolted or welded down?
Old Dec 20, 2003 | 07:11 PM
Default Re: Cusco Cage In 96 Coupe? (shaun311)
bolted in.
Old Dec 20, 2003 | 09:47 PM
Chris y0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
wow... that looks safe... front roll bars with no padding, no airbags, and stock seat belts
Old Dec 20, 2003 | 09:54 PM
Default Re: Cusco Cage In 96 Coupe? (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">
wow... that looks safe... front roll bars with no padding, no airbags, and stock seat belts </TD></TR></TABLE>
the bars hug the roof and pillar very tight, right up against it. i'm short, so my head is pretty far away. i don't like airbags, because i've been wacked before. stock seat belts? stop hatin..
Old Dec 20, 2003 | 09:57 PM
thrty8street's Avatar
so how much would one of these roll cages go for?and where to get em?
Old Dec 20, 2003 | 09:59 PM
Default Re: (thrty8street)
i got mine for $630. you can get it at http://www.machiii.net or http://www.heeltoeauto.com
Old Dec 20, 2003 | 10:00 PM
Chris y0!'s Avatar
owned
Old Dec 20, 2003 | 10:06 PM
owned</TD></TR></TABLE>
hehe...
Old Dec 20, 2003 | 10:24 PM
Default Re: (Airbag Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club &raquo;</TD></TR><TR><TD CLASS="quote">i got mine for $630. you can get it at http://www.machiii.net or http://www.heeltoeauto.com</TD></TR></TABLE>
how much was the shipping?
so how much is shipping?
Old Dec 20, 2003 | 10:29 PM
$630 OTD. &lt;~ hookup price
Old Dec 20, 2003 | 11:24 PM
FredoSP's Avatar
anymore pics?
Old Dec 20, 2003 | 11:29 PM
EkREV's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if Cusco makes a 6 point cage for the 96 civic coupe. I know that they make for the HB, but not sure if the HB application fits the coupe. So, with the cage, is it possible to have passengers sit in the back?
Thank in advance... </TD></TR></TABLE>
what model do you have? if you have a ex or hx w/ a sunroof, then it wont fit. you'd have to cut and weld for it fit. if you got a dx then it will fit w/o any problems.
Old Dec 21, 2003 | 07:24 AM
Default Re: Cusco Cage In 96 Coupe? (EkREV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkREV &raquo;</TD></TR><TR><TD CLASS="quote">
what model do you have? if you have a ex or hx w/ a sunroof, then it wont fit. you'd have to cut and weld for it fit. if you got a dx then it will fit w/o any problems. </TD></TR></TABLE>
i have a HX withOUT sunroof. So i presume it will fit with no problems?
how about people sitting in the back? Is that still possible with my coupe?
Old Dec 21, 2003 | 09:17 AM
EkREV's Avatar
New User
how about people sitting in the back? Is that still possible with my coupe?</TD></TR></TABLE>
im sure it is possible for passengers to sit in the back but it would be unsafe. prolly put some padding on it or something.
Old Dec 21, 2003 | 09:22 AM
dankbudz11357's Avatar
don't believe you can get an hx with a sunroof.
but anyways, i like how the cage curves around the dash.
Old Dec 21, 2003 | 09:29 AM
EkREV's Avatar
New User
Default Re: Cusco Cage In 96 Coupe? (dankbudz11357)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dankbudz11357 &raquo;</TD></TR><TR><TD CLASS="quote">don't believe you can get an hx with a sunroof.
but anyways, i like how the cage curves around the dash.</TD></TR></TABLE>
it curves around the dash, but since the cage is made for LHD cars, you wont be able to use your glove box.
Old Dec 21, 2003 | 02:08 PM
it curves around the dash, but since the cage is made for LHD cars, you wont be able to use your glove box.</TD></TR></TABLE>
yea, the cage blocks the usage of the glove box by about 1.5 inches. i didn't want to give up the use of my glove box, so i hacked off a portion of it. it is a bit ghetto right now, but i will try to fix it up later on.
Old Dec 21, 2003 | 02:12 PM
navin's Avatar
there's no harness' bar?
Old Dec 21, 2003 | 03:19 PM
carl_aka_carlos's Avatar
Default Re: (navin)
something about that cage just makes me cringe. don't know if it's the lack of padding or the lack of a harness bar. i just can't imagine that actually doing anything besides adding weight.
Old Dec 21, 2003 | 03:29 PM
743power's Avatar
Default Re: (carl_aka_carlos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carl_aka_carlos &raquo;</TD></TR><TR><TD CLASS="quote">something about that cage just makes me cringe. don't know if it's the lack of padding or the lack of a harness bar. i just can't imagine that actually doing anything besides adding weight.</TD></TR></TABLE>
Or the lack of a diagonal bar in the main hoop. Sadly enough, cages like that are the norm in Japan.
