slick size for 11's
you want the M&H 24.5x8.5x15's. they will be perfect for your application. and even aired to around 6.5-7.5, you shouldn't break any axles. as long as everything else is set up correctly. you could see 11.60-11.80 if you have 350 to the wheels in an integra.
thanks a lot guys.
I got a deal on slightly used 23.5x7.5's so I might pick them up and use them this next year then pick up some slightly bigger ones.
what kind of wheels should I look for and what width? I am on a budget cause I am building the motor over winter but I figure I can have all the motor I want if I don't have traction I am goin no where
