Mastercylinder leaking?
Old Dec 19, 2003 | 04:30 PM
SiR-G96's Avatar
Default Mastercylinder leaking?
Hi!
I've just changed my brake fluid on a gsr, now my brake pedal sinks slowly with the car started. If the car's off, the pedal don't sink! I've checked and there is no leaks! Im wondering if my BMC is leaking internally or the booster is dead?! or could it be just bubbles in the lines?
Thank you!
Old Dec 19, 2003 | 04:44 PM
Dan GSR's Avatar
Default Re: Mastercylinder leaking? (SiR-G96)
did you bench bleed the MC
then flush the whole sytem??
do those first
you def have air
Old Dec 19, 2003 | 06:52 PM
X2BOARD's Avatar
Default Re: Mastercylinder leaking? (Dan GSR)
pedal sinking is more like leaking MC seal... but as mentioned, bench bleed the MC... BUT, if you didn't replace it... you shouldn't need to.
Old Dec 19, 2003 | 07:54 PM
Bob GS's Avatar
I have the same problem on my 1990 Integra GS but its intermittent the brake petal will slowly sink to the firewall but not all the time and there aren't any leaks and the reservoir
stays full anyone know if its the master cylinder, the booster or the vacuum check valve?
Old Dec 19, 2003 | 07:58 PM
mickey513's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR-G96 &raquo;</TD></TR><TR><TD CLASS="quote">Hi!
Thank you!</TD></TR></TABLE>
I have the same problem on my gsr. At first I thought I got air in the system so I bleed the whole thing again. Same problem, so I knew it wasn't air. I pretty sure it's the MC, I bought a rebuilt one but havn't found the time to install it.
Old Dec 20, 2003 | 10:15 PM
SiR-G96's Avatar
Thanks everyone!
I found the problem!
MC is leaking internally! Pedal sinks less or non when cold, and sinks faster when hot. Because MC metal houseing expand more than the rubber piston seal!
My MC died - Internal Bleeding!
Thanks again
Old Dec 21, 2003 | 08:06 AM
mickey513's Avatar
Cool, I bought my master cylinder rebuilt from autozone.com with a lifetime warranty for $90.
Old Dec 21, 2003 | 09:17 AM
Rah Rah's Avatar
Default Re: Mastercylinder leaking? (mickey513)
If you bled the system, replace the MC and call it a day.
eh9deux
17
Jun 13, 2011 07:33 AM
spintboy
17
Jan 3, 2008 08:49 AM
s10cky
17
Dec 20, 2006 07:19 PM
stripes777
Oct 28, 2006 11:16 PM
bOOsTiNSoHcVtEc
May 27, 2004 12:58 PM
