Code 13?
Old Dec 19, 2003 | 11:46 AM
A.P.'s Avatar
Default Code 13?
My car is all stock 91 honda civic si. While driving around the check engine light came on. Looked at the ECU and the code generated is 13. What is an atmospheric pressure senor and where is it located?
Old Dec 19, 2003 | 01:14 PM
Donkey85's Avatar
Default Re: Code 13? (A.P.)
the pa sensor converts atmospheric pressures into voltage signals and sends them to the ecu. the signals then modify the basic discharge duration to compensate for changes in the atmospheric pressure. as to where it is located i'm not sure on that one. i hope sobody else can help you on the second part... good luck
Old Dec 21, 2003 | 07:58 PM
A.P.'s Avatar
Thanks for the info.
skill178
Sep 12, 2011 09:23 AM
happyabortion
May 13, 2008 04:18 PM
lscrxhf
Jul 4, 2006 08:08 AM
THE FUCATYPR HATCH
Jan 27, 2005 09:17 PM
crxsiperf
Feb 26, 2004 08:29 PM
