ZC into EF civic which driver side mount?
Old Dec 19, 2003 | 10:00 AM
WONG FRIED RICE's Avatar
Default ZC into EF civic which driver side mount?
need to know which mount do i use for a ZC motor into the civic
Old Dec 19, 2003 | 10:09 AM
tpr's Avatar
tpr
Default Re: ZC into EF civic which driver side mount? (JDMB16ACRX)
You use the standard EF mount!
Old Dec 19, 2003 | 01:20 PM
so basically the block mount i take off the A6, and put it on the ZC? will that work?
Modified by JDMB16ACRX at 2:33 PM 12/19/2003
Old Dec 19, 2003 | 03:28 PM
Outsane's Avatar
use either.. the ZC and the d16 mounts are the same..
Old Dec 19, 2003 | 03:37 PM
another_crx's Avatar
Default Re: ZC into EF civic which driver side mount? (Outsane)
stock mounts
Old Dec 19, 2003 | 04:43 PM
well, for some odd reason, the block mount on the ZC is different from the A6 one..... so yea...i'm kinda lost.... if i took the block mount off the A6 would it fit onto the ZC?
Old Dec 19, 2003 | 06:05 PM
virginia_dude's Avatar
My zc bolted up to my factory mount. If it doesn't you bought the wrong ZC, There is a Civic DOHC black top and an Integra ZC blacktop, the mounts are different.
Old Dec 19, 2003 | 07:35 PM
jlicrx's Avatar
is this a DOHC ZC or SOHC ZC?
Old Dec 19, 2003 | 07:46 PM
JonGP4's Avatar
Default Re: ZC into EF civic which driver side mount? (jlicrx)
yeah i just put in my DOHC ZC this week, and noticed the driver side mounts were different.. so i took the bracket and mount off my a6 and put in on the ZC.. one bolt is not used.. but it lined up fine
Old Dec 20, 2003 | 09:45 AM
Default Re: ZC into EF civic which driver side mount? (JonGP4)
okay so the main thing is that i can use the A6 mount and put it on the ZC block.
which is what i'm looking for! thanks!
oh yea, it is the DOHC one.
crxboy909
Sep 17, 2009 06:39 PM
turbozcteg
Nov 5, 2005 06:13 PM
CBURKE
Aug 13, 2005 02:56 PM
chrisblack
Jan 26, 2005 11:03 PM
jaymoney1823
Nov 5, 2002 07:06 AM
