mpfi swap- no codes, starts fine then stalls HELP!
Old Dec 19, 2003 | 08:25 AM
W0oT's Avatar
Banned
Default mpfi swap- no codes, starts fine then stalls HELP!
hey all i've finished my d15 ---> d16 swap in my 89 dx. i have no codes on my ecu.... all connections were soldered and depinned.... well when i start it now (20 deg f temp) it stalls out when the idle kicks down after about 10seconds of running.... i've tried swapping the 2 white wires at the dizzy, but when i do it won't start at all.... so i switched them back... starts but dies when idle drops..... i swapped my tps wires.. also when i touch the gas pedal. the car doesn't rev up but just dies also.... HELP!!!
i've searched..... tried everything w/ no luck.... i thought it was caused by the vss code i had before but i fixed that.... and besides that wouldn't cause the problem anyways.....
Old Dec 19, 2003 | 08:30 AM
Grease Monkey's Avatar
Default Re: mpfi swap- no codes, starts fine then stalls HELP! (Nismo240sx1)
did you try opening the throttle a bit?
Old Dec 19, 2003 | 09:59 AM
W0oT's Avatar
Banned
Default Re: mpfi swap- no codes, starts fine then stalls HELP! (Grease Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">did you try opening the throttle a bit?</TD></TR></TABLE>
well...... no but isn't stepping on the gas pedel the same as opening the throttle.... if so when i step on the gas it revs up a little then dies..
Old Dec 19, 2003 | 10:12 AM
hmmmm....
Old Dec 19, 2003 | 10:18 AM
W0oT's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm....</TD></TR></TABLE>
my thoughts exactly, it wasn't pulling this sh*t a week ago...
Old Dec 19, 2003 | 10:33 AM
**EDIT** Check your idle air control valve
Old Dec 19, 2003 | 12:02 PM
W0oT's Avatar
Banned
ok now i'm getting a code 16....... for bad injector... each one is getting power though becuase i unplugged each one individually while motor was running, and each time motor would get pissed.
i use to get a code for iat sensor.... maybe i should swap it out.
Old Dec 19, 2003 | 12:04 PM
W0oT's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">**EDIT** Check your idle air control valve</TD></TR></TABLE>
i unplugged it and started the motor, does the same thing..... well motor will idle now but as soon as i mess w/ throttle it wants to stall.
Old Dec 19, 2003 | 12:10 PM
seems like you may have pluged the IAT plug and IACV plug. Swap them.. did you try that yet? Maybe you confused the two and plugged the wrong one.
Old Dec 19, 2003 | 12:23 PM
W0oT's Avatar
Banned
i just went out and took some pics i'll post em
Modified by Nismo240sx1 at 4:48 PM 12/19/2003
Old Dec 19, 2003 | 12:24 PM
k
Old Dec 19, 2003 | 12:53 PM
do u have aim? IMme so i can help you
Old Dec 19, 2003 | 01:18 PM
W0oT's Avatar
Banned
yea i got aim: SN- Simon ibp what's yours
Old Dec 20, 2003 | 03:52 PM
crxspd89's Avatar
try and undoing the bolts on the distributer, and kind of turn it and see if u can get a better sound out of it, thats what was wrong with my car when i put my new engine in, but let me know what happens
Old Dec 20, 2003 | 08:09 PM
quick4thgen's Avatar
Default Re: (Nismo240sx1)
WHAT ECU ARE YOU USING. I THINK YOU SHOULD BE USING A PM6 NOT A PM9.
Old Dec 20, 2003 | 08:24 PM
W0oT's Avatar
Banned
Default Re: (quick4thgen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quick4thgen &raquo;</TD></TR><TR><TD CLASS="quote">WHAT ECU ARE YOU USING. I THINK YOU SHOULD BE USING A PM6 NOT A PM9.</TD></TR></TABLE>
pm6 where did you get pm9 from?
Old Dec 20, 2003 | 08:58 PM
nevermind i was thinking of the stock dual point ecu
Old Dec 20, 2003 | 09:01 PM
Carnivore's Avatar
Jim, its Dave, i can't really tell you whats wrong with the MPFI swap, jus get it working right and then lets do it to my civ, lol, mabye a vaccum problem? idk
Old Dec 20, 2003 | 10:22 PM
JonGP4's Avatar
Default Re: (Carnivore)
first thing i noticed from looking at the pic.. is you have your Map sensor and Evap Purge vacume lines reversed.. but i doubt thats ur problem.. u did wire in a resistor right? for the injectors?.. also what injectors are you running? they should be OBD0.. if anything.. swap out your ECU with a known good one.. it could be that.
Old Dec 20, 2003 | 10:45 PM
W0oT's Avatar
Banned
Default Re: (JonGP4)
[QUOTE=JonGP4]first thing i noticed from looking at the pic.. is you have your Map sensor and Evap Purge vacume lines reversed.. QUOTE]
i think your right from this pic i have.... 21 and 12 are backwards right?
i'm using the obd0 injectors
Old Dec 20, 2003 | 11:18 PM
JonGP4's Avatar
yeah 21 and 12.. umm.. first things first.. if you have extra injectors give those a shot.. its gotta be fuel related i think.. check the wiring to your injectors.. and or replace them.. then try the ECU.. that's what i'd do
Old Dec 22, 2003 | 01:42 PM
tgreaves's Avatar
Do you hear the fuel pump comming on.. If your fuel pump isnt turning on youll get a code 16.. I did..
Old Dec 23, 2003 | 08:10 PM
W0oT's Avatar
Banned
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Do you hear the fuel pump comming on.. If your fuel pump isnt turning on youll get a code 16.. I did..</TD></TR></TABLE>
yup fuel pump comes on
Old Dec 24, 2003 | 06:47 AM
I think I know what is going on now. Fixed my friends MPFI swap. Your dashpot maybe bad. Try this, unplus the vaccum hose on #6. Goes from the dashpot to the first vaccum line on the intake mani. Start your car. If your car starts with no problems then you know its the dashpot. With the car running plug back the vaccum line for #6 in the diagram and see if you car stalls. Most likely it will because the dashpot recieves vaccum and what it will do now is apply vaccum which will close the throttle plate. All we did from there was replace the dashpot a BAM the car is now running great! Let me know if this helped you out alittle PM me or AIM me at greasem0nkey29@aol.com
Old Dec 27, 2003 | 10:02 AM
W0oT's Avatar
Banned
Default Re: (Grease Monkey)
so yea, removed the dashpot, car idles fine, but boggs and no power over 10% throttle, checked timing, it's set around the red mark or 1 mark from right (2 marks away from left side).
