bearing thickness
Old Dec 19, 2003 | 05:15 AM
lillex's Avatar
Default bearing thickness
is there a chart that shows the actual bearing thickness per color of bearing
b20z block
Old Dec 19, 2003 | 11:37 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: bearing thickness (exhondatech)
probably not. just call up your local honda dealership or get some acl bearings, they're universal.
Old Dec 19, 2003 | 05:02 PM
Rocket's Avatar
Default Re: bearing thickness (vtecb20coupe)
If I remember correctly it's
Black, Brown, Yellow, Green, Pink, Red
Each being about 0.0002" thicker going from left to right.
Old Dec 19, 2003 | 08:43 PM
b19coupe's Avatar
Default Re: bearing thickness (Rocket)
And don't forget blue, for when you want those really tight clearances
earl
Engine Machining & Assembly
Jun 8, 2012 09:38 AM
hondaapi
Nov 23, 2005 04:29 AM
earl
Dec 25, 2003 10:04 PM
