Car burning distributor HELP????
Old Dec 18, 2003 | 11:22 PM
CB_ejcoupe's Avatar
Default Car burning distributor HELP????
I just finished dropping a LS motor in my 91 hatch. Car was a std 4spd. MPFI swap was done car ran like a champ, then i dropped in tha LS like 2 months after tha mpfi swap. There is 2 plugs on the dizzy, 1 big plug tha other is little. The wires that burn are on the little plug, the colors that burn are black with yellow line and a blue wire they both melt. My car has burnt 2 dizzy's. I need help, dont know whats wrong.
Old Dec 20, 2003 | 03:04 PM
CB_ejcoupe's Avatar
Default Re: Car burning distributor HELP???? (CBtech)
help
Old Dec 26, 2003 | 02:12 PM
Jet Black's Avatar
Those wires send signals for the tach and I believe to the ecu....from the sounds of it they shorted out and the extra current melted them....you might wanna check if there is continuity between the blue wire and ground, then black wire and ground...
Now sure what spec is, you'll have to look it up in a manual
Adam_0115
Apr 14, 2016 05:11 AM
k3nda13
May 19, 2011 12:55 PM
Mr.vang
Feb 14, 2008 04:33 PM
budget_hatch
Apr 22, 2006 01:46 AM
Hcivic88
16
Mar 7, 2004 12:51 PM
