jdm b18c water pump bolt torque
Old Dec 18, 2003 | 09:39 PM
.Hookedonhatch.'s Avatar
Default jdm b18c water pump bolt torque
Whats up i was wondering if anyone knows how many foot pounds to torque the water pump bolts and if any what order. Also should i hondabond the the gasket on both sides or just the side touching the the block. Thanks
Old Dec 19, 2003 | 01:19 AM
IN VTEC's Avatar
Default Re: jdm b18c water pump bolt torque (Hookedonhatch)
It's 8.7lb*ft, but if you just get them snug with a 1/4" drive ratchet, that'll be fine too. They're just 6mm bolts, so they don't and can't take a lot of torque.
No Hondabond necessary. Just make sure the gasket is there and undamaged.
loveformycivic
Aug 9, 2014 04:54 PM
LdySheri
Dec 28, 2010 05:01 PM
hatchdrvr
Jan 26, 2007 04:08 AM
del_parker
May 14, 2003 04:58 PM
