Steering Wheel Squeak?
This is for an '02 EP-3. Does anyone else have this? It is intermitant and seems to do it more after long highway stretches. It seems like the plastic is rubbing or something where the wheel connects to the ignition column. Any suggestions or comments?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Web_Head »</TD></TR><TR><TD CLASS="quote">This is for an '02 EP-3. Does anyone else have this? </TD></TR></TABLE>
Nothing like that over here, with 24,000 miles on it.
Some of the DC2 ITR people complain of something similar, but I don't have that problem on my ITR, either.
If nobody has any suggestions, you might want to search archived posts in the ITR Forum for how those guys found and solved the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
If nobody has any suggestions, you might want to search archived posts in the ITR Forum for how those guys found and solved the problem.</TD></TR></TABLE>
Tons of the ep3 guys are having this problem ...
http://www.ephatch.com/forum/s...ering
Thanks for the suggestions.
The squeak has actually been going on for a while. I think it started around 25,xxx
miles or so. I was going to take it to the dealer but I am so busy and live about 100 miles away from the closest one. I am now at about 63,500 miles so warranty won't help me now. From reading the posts in the link, it sounds like most dealers don't know how to fix the problem anyway.
I am going to try spraying some silicoln lubricant in between the wheel and the column. Any reasons why I shouldn't do this?
some have found that the stock strut dust boot is rubbing on the spring seat causing the squeak. simply pulling down on the dust boot removes the squeak, but would seem temporary. a more permanent solution should be found. i haven't tried it yet on mine, maybe this weekend.
Modified by glw at 6:02 AM 12/24/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glw »</TD></TR><TR><TD CLASS="quote">some have found that the stock strut dust boot is rubbing on the spring seat causing the squeak. simply pulling down on the dust boot removes the squeak, but would seem temporary. a more permanent solution should be found. i haven't tried it yet on mine, maybe this weekend.
Modified by glw at 6:02 AM 12/24/2003</TD></TR></TABLE>
Cool, I'll try that.
Island_Krush
Mar 1, 2008 01:17 PM
AntonioH
Nov 21, 2006 02:12 AM
