b18b in 89 si wiring questions
Old Dec 18, 2003 | 05:59 PM
hondaeg5's Avatar
Default b18b in 89 si wiring questions
sorry guys i searched and really didnt get what i was looking for. what i need to know is what wiring needs to be done. the ecu is an obd1 ls,distributor is a obd1,injectors are obd1 and the engine harness is for the 89 si. blown90hatch made the conversion harness for the ecu. what else if any needs to be done? do the injector clips need to be modified? also the distrinutor,whats needs to be done there? TIA
Old Dec 18, 2003 | 06:22 PM
VTECVillain's Avatar
Default Re: b18b in 89 si wiring questions (hondaeg5)
Talk to blown90hatch, he did a write up on OBD0 to OBD1 and what all is involved if I'm not mistaken. Since you already have MPFI wiring, it will make the conversion easier. You'll need to rewire the injectors, eliminating the resistor box. You'll have to run wiring for a 4 wire O2 sensor, some distributor wiring (plugs and such), etc. It's not that hard when you have it all in front of you, it does take some work though.
Old Dec 19, 2003 | 03:46 AM
hondaeg5's Avatar
Default Re: b18b in 89 si wiring questions (VTECVillain)
thanks 4th gens and b series are new to me
Xathine
May 5, 2013 08:51 PM
sliiiiced
Jul 7, 2010 07:50 PM
89 JDM CRX
Jun 20, 2004 09:38 PM
89 JDM CRX
Mar 21, 2004 01:49 PM
