I'm Looking To Get More Compression! Your Input Needed!
Old Sep 22, 2001 | 05:30 AM
slowcivic's Avatar
New User
Default I'm Looking To Get More Compression! Your Input Needed!
Here's the deal: I have a 95 USDM GSR Engine with about 70Kmi. The Head has been Milled .026" and is running 11.3 to 1 Compression. I'm running 10 to 1 compression Endyn Rollerwaves with 81.5mm bore. Future plans include installation of Toda Spec. Cs and the Toda Valvetrain components. I need options on how to raise my compression to get the most out of the Spec. Cs, but not have to worry about Piston to Valve Clearance Issues. Your input would be much appreciated! Thank you!
Old Sep 22, 2001 | 05:57 AM
rainforest's Avatar
Default Re: I'm Looking To Get More Compression! Your Input Needed! (slowcivic)
why did you get 1 point over stock compression endyn pistons and mill the head. if you tell endyn what cams you are running they will customize the valve relifes for you . what did you tell larry you were using for cams. because if you said toda 3's you could prolly go to around a 11.1 comp piston with your milled head. call larry at endyn. Or go to http://www.theoldone.com bbs.
Old Sep 22, 2001 | 08:14 AM
slowcivic's Avatar
New User
Default Re: I'm Looking To Get More Compression! Your Input Needed! (rainforest)
Rainforest, at the time I ordered the Pistons from Larry, I was and still am running Skunk2 (second batch) Cams. Larry suggested I get the 10 to 1 Compression Rollerwaves. At that time I was not considering the Todas. Thanks for your comment!
Old Sep 23, 2001 | 06:58 PM
slowcivic's Avatar
New User
Well, I just purchased a Stock 95 GSR Head, so will be using that with Toda High Compression Pistons.
90efhatch
Jul 30, 2011 05:12 PM
06BlackSi #45
Honda Civic (2006 - 2015)
11
Jan 16, 2007 12:32 AM
red civic standard
Dec 12, 2005 08:49 AM
Ger_Mugen_Civic
Nov 5, 2004 07:35 AM
blazin
Jan 6, 2002 07:31 PM
