need help on my 91 si b16 sawp
ok ,i have a 91 civic si , I'm doing a b16 sawp with a Pwo ecu,I have put in the motor hook up all the wire and i start the motor and i'm getting code 3,7,21 . Is there any other wire i have to cut or move around Thank
Modified by civc 91 at 12:34 AM 12/19/2003
the code 7 is ur tps (throttle position sensor) u need to setnit at .5 volts with a multimeter. ill try to find out the other i gust know code7 because i had the same problem on my b16
beatthisspeed69
Mar 25, 2006 06:05 PM
ovrbst
Aug 25, 2003 07:18 PM
kizner
Mar 8, 2002 07:03 PM
