will siR shaft work with hydro?
Old Dec 18, 2003 | 11:25 AM
type Gendy's Avatar
Default will siR shaft work with hydro?
Will the y1/siR intermediate shaft work with anything besides cable trannies? Does anyboyd know?
Will it work on a hydro bseries tranny?
Old Dec 18, 2003 | 11:31 AM
VTECVillain's Avatar
Default Re: will siR shaft work with hydro? (sick hatchem)
Yes, just use the proper driver's side axle (90-93 Integra). You'll also need to change the driver's side tranny seal to a 90-93 Integra seal.
Old Dec 18, 2003 | 11:36 AM
type Gendy's Avatar
Default Re: will siR shaft work with hydro? (VTECVillain)
So say its going in a 5g hatch, you have to change the tranny seal, and then use the appropriate axle combo......?
Say 88 hybrid teg axle on passenger and 90-93 driver side
Old Dec 18, 2003 | 11:42 AM
QUOTE=sick hatchem]So say its going in a 5g hatch, you have to change the tranny seal, and then use the appropriate axle combo......?
Say 88 hybrid teg axle on passenger and 90-93 driver side[/QUOTE]
No need for a hybrid axle. You can use the 90-93, 94-01 Integra's, or 99-00 Civic Si passenger side axle.
Old Dec 18, 2003 | 11:45 AM
type Gendy's Avatar
Oops, i meant hybrid passenger side.
90-93 teg axles won't work across the board with the y1 shaft
Old Dec 18, 2003 | 11:54 AM
Ok it's the driver's side that needs to be the hybrid axle then. The driver's side axle is the one that goes into the intermediate shaft, so the Y1 being the oddball shaft would make the 90-93 Integra axle not fit. You can still use the passenger side axles that I mentioned, the driver's side would need to be the hybrid axle.
Due to the need for a hybrid axle, it would be easier just to get a 90-93 or 94-01 Integra intermediate shaft and the proper stock axle combo.
Old Dec 18, 2003 | 11:57 AM
type Gendy's Avatar
Thats what i did, but i am trying ot get a few bucks for the y1 shaft, which is hard because nobody feels like dealing with the hybrid axle (which is the same thing i did).
aojtin
Mar 6, 2009 12:26 PM
IT GUY
Aug 29, 2007 10:47 AM
hybrid1990crx
Apr 4, 2005 08:09 AM
migs
Jul 22, 2004 02:41 PM
johnzm
Sep 1, 2002 07:37 AM
