Question About My Shift Linkage & Shifter
I use the Hasport Shift linkage with my B-series swap in my 91 si hatch.....
I have a red generic gsr style short shifter with ES poly bushings and when i put it in gear it has WAY to much play. For instance, Put it in first gear and you can move it side to side at least 3-4 inchs. I got under the car and tighten the shifter bolt and it still done it. Anyone else experiancing the same problem ???
I had the same problem with a custom made shift linkage and a JG/Lightspeed short shifter. I replaced it with an SiR shift linkage and shifter and all is better now.
I think that short shifter sucked, that I had...
Also, forgot to menchion.......
Sometimes when i go to put it in gear or pull it out of gear its almost like i got to use two hands to put it in or pull out.
88EFhatch
14
Jun 8, 2005 06:11 PM
erikiksaz1
Mar 28, 2005 01:51 PM
sloweh3
May 7, 2004 04:34 AM
