USDM Type-R Head on a USDM GSR Block?
I have also heard that you loose something like .3 in compression, can't remember exacly why, something to do with the shape of the combustion chamber or something. I have definitely heard that you would loose compression though. Advantages would be: better cams, lighter and larger valves, stiffer valve springs, and light headwork.
Correct...the gsr has a smaller combustion chamber. That is why when you put the Type-R head on it will drop the compression by around .3. The type-r has a bigger quench area.
