one blink on PM6 ECU trouble code LED = O2 sensor?
I pulled my carpet and checked out my ECU and found it was blinking once steadily, kinda like the "security" led on an OEM Honda radio, and apparently this indicates a problem with the O2 sensor.
I reset it by pulling both the ECU and Hazard fuse under the hood, and it didn't come back.
I know that sometimes in the past my check engine light has come on when the car is fully warmed up and the engine is coasting down from a higher rpm under light or no load.
Chilton's says if the ECU code/check engine light doesn't come back after resetting it, it could just be a bad connection issue. I did extend the O2 wire b/c I have a header - could this be it?
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
if an O2 sensor is old and "lazy" it will trigger the code once in a while...
mine does it on the average of couple of months or so. replace your sensor if you can, as it is most likely making your car run rich.
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK »</TD></TR><TR><TD CLASS="quote">i gota bosch universal one wire o2 sensor at avdnaced auto for 18$ and it solved the problem.</TD></TR></TABLE>
I've used these in 3 car's that I've owned which use single wire O2's. They are cheap and I never had any trouble with them, still using one 3 years and counting.
the_0ne
Jul 16, 2006 08:01 PM
bumthology
Oct 5, 2004 03:18 PM
DreamSpeed
Jan 13, 2002 11:29 PM
