water temp gauge
easiest way is to use a tee in the upper radiator hose so you can put the sender in it. I think http://www.acautotechnic.com has them
you can splice into your water temp sender, its a 1 wire going into the passenger side of the head. that goes to the sending terminal on the back of the gauge.
