1-2 shift and massive wheel hop
Old Sep 21, 2001 | 01:22 PM
yellow blur's Avatar
Default 1-2 shift and massive wheel hop
hey guys, so i was taking off from a light today, not launching or anything, and i shifted hard before redline, i expected to hear a chirp but all i ended up with was massive wheel hop. i remember hearing that wheel hop isn't very good, and i know to remedy this would be some bushings etc.
my question is, is this normal for our cars to instead of chirp, just give wheel hop?
Old Sep 21, 2001 | 01:29 PM
The Kernel's Avatar
Default Re: 1-2 shift and massive wheel hop (yellow blur)
Never happened to me before.
Old Sep 21, 2001 | 01:38 PM
Type Goch's Avatar
New User
ive never really experienced a hop unless i wasnt on full throttle and just shifted quickly and gassed it right after. Chirp isnt necessarily good either, which is a loss of traction. Look into energy suspension mounts or something...
Old Sep 21, 2001 | 01:45 PM
Dropspeed's Avatar
Default Re: 1-2 shift and massive wheel hop (Type Goch)
Do you have larger than stock wheels and are you making more power than stock?
Because my car did it all of the time on hard 1-2 shifts with the 17" on it. I have poly bushings in and that helped but I just recently eliminated the problem by installing the Z10 radius arm kit.
Later Mattj
Old Sep 21, 2001 | 01:46 PM
Default Re: 1-2 shift and massive wheel hop (Dropspeed)
nope, my car is all stock right now. i know that a chirp is a sign that im losing traction, but i didnt expect the wheel hop to be so intensive. it was as if i was launching at a drag strip, which i have expereinced a LOT of wheel hop. oh well, i'll just take it easy on my car and see what develops.
Old Sep 21, 2001 | 01:56 PM
Dropspeed's Avatar
My other qwik thought is you might check the tire pressure. I didn't experiance a wheel hop problem when the car was running on the 15s
Mattj
Old Sep 21, 2001 | 01:57 PM
thanks, i'll check that out. it's been pretty hot here lately, the pressure might have gone up.
Old Sep 21, 2001 | 03:22 PM
venom's Avatar
ES motor mounts will cure that problem!
Old Sep 21, 2001 | 03:27 PM
ic108's Avatar
New User
Default Re: 1-2 shift and massive wheel hop (NBP #0933)
i know that my friend brian in his 94 hybrid has wheel hop going into 4th GEAR!!!!!! the dash nearly falls into your lap. needless to say the car hauls serious ***. my experience is that it all depends on the tires. i know that if you are running on lets say nitto 450's or something which absolutely suck for traction, the tires are going to spin and not grab the raod. on the other hand, if you have a nice set of sticky tires, wheel hop is definite because the tires are trying stick to the road. i would say that you probably have some decent tires and not to worry about it. make sure that your CD player is secure in the dash
jeff
Old Sep 21, 2001 | 03:33 PM
flex97itr's Avatar
Default Re: 1-2 shift and massive wheel hop (jpGSR)
i get wheel hop all the time... my dash feels like its going to fall apart. i also have nitto 555 drag radials. try a differnt tire and see if you get the same reaction.
Old Sep 21, 2001 | 10:58 PM
lotus's Avatar
New User
Default Re: 1-2 shift and massive wheel hop (flex97itr)
O..O..O... Tell me more about the ES motor mounts and the Z10 radius arms... It rains a whole bunch out here and the wheel hop in the wet empties my glove box every time ( No dry hop though )
I would love a cure...
Old Sep 21, 2001 | 11:02 PM
Type Goch's Avatar
New User
it might also be that your tires arent catching or theyre losing traction during the shift..
Old Sep 22, 2001 | 01:05 AM
SleepyR's Avatar
New User
I also get alot of wheel hop
Old Sep 22, 2001 | 01:10 AM
evil vapor's Avatar
Default Re: 1-2 shift and massive wheel hop (Gotenks)
ed, try not to shift hard or too fast, it's a killer on powertrain (tranny, axles) and basically everything.
Old Sep 22, 2001 | 05:19 AM
R spec's Avatar
New User
i get a little wheel hop when launchin at 5.5Krpm launch slip the clutch, and dont go full throttle till you know the tyres have traction then when it regains traction......go all the way!
[Modified by R spec, 2:21 PM 9/22/2001]
Old Sep 22, 2001 | 05:23 AM
R spec's Avatar
New User
Default Re: 1-2 shift and massive wheel hop (vaporsi)
i feel IMO smothness is the key to get good accelaration times etc.....
Old Sep 24, 2001 | 10:00 PM
lotus's Avatar
New User
Default Re: 1-2 shift and massive wheel hop (R spec)
what...no info on radius arms or mounts to cure the problem?
It obviously doesn't rain in California..
Just call me hoppy...
Old Sep 25, 2001 | 04:55 AM
Balls's Avatar
What exactly does wheel hope feel/sound like?
Old Sep 25, 2001 | 10:55 PM
lotus's Avatar
New User
Default Re: 1-2 shift and massive wheel hop (*****)
wheel hop is kinda like having a power glove box door
So how do you guy's cure your wheel hopping?
Old Sep 26, 2001 | 11:47 AM
PM-Performance's Avatar
Default Re: 1-2 shift and massive wheel hop (lotus)
depends, sometimes, mine will chirp and sometimes hp alot, depends how hard i shift and hit it, wheni hit it harder i think it hops. . . . . . cant anymore though, my clutch is shot now it just bogs out. . ugh, putting in my act this weekend though.
K7-1Ktrevor
Suspension & Brakes
Nov 20, 2009 09:37 AM
stivic
Dec 10, 2004 02:41 PM
msmithgsr2131
Feb 16, 2004 08:59 AM
brega3
Apr 22, 2003 08:07 PM
LostGsr
Apr 27, 2002 02:35 PM
